Jira: location of the email error queue?
Brent Webster
August 29, 2012
Where is the directory location of the email error queue in Jira. I know it sent by a Java module (SMTP?) but I'll like a more in depth review of the email sent failures.
Background:
I don't normally check Jira's email error queue but I did this morning and found 373 emails unsent since mid July. Most are from velocity templates I created 8 months ago and have not had an issue with. Most emails generated by these templates are still successfully sent out. I also ensured that each individual user could successfully be sent an email. I put these 373 failed emails back into the queue and 120 were successfully sent. I believe it is my ISP's SMTP that is hosing my email but I need explicit details.
Any pointers on debugging would help-- Thanks.
JamieA
August 29, 2012
SMTP is the wire protocol by which any application speaks to the SMTP mail server, for sending email.
The error queue is not on disk or in database, it's in memory, so if you restart jira it's gone.
Best way to work out the problem is to turn on mail debug logging (see atlassian docs), which will tell you if the connection was refused or whatever.
Brent Webster
August 29, 2012
Excellent, lots of logs to shift through but now I have some details.... Thanks
Tatiana Jancusova May 12, 2014
how did you resolve this issue? I habe over 6000 items in the error queue and can't send all of them.
Brent Webster
May 12, 2014
So many issues since this one but I believe it was a misconfigured SMTP server when our company was bought out by Ericsson. Not sure of specifics -- sorry I can't be of more help.
Like Sanaz Hosseinzadeh likes this
