Jira-misc-workflow-ex – How to validate a custom field value on a transition
Steven Baynes April 21, 2022
Using Jira workflow extensions, how can I validate that a custom field has a particular value?
Example:
If Custom_Field1 = ‘Yes’, then allow the transition to occur, else don’t allow the transition.
Ed Gaile _Atlanta_ GA_
April 21, 2022
If you are using JMWE, you can us the Scripted (Groovy) Validator and just define the custom field logic in the Groovy script section.
issue.getAsString("customfield_1234") == "Yes"
Steven Baynes April 22, 2022
Our Jira instance does not have Script Runner (Groovy) installed. So would your suggestion work? We have PowerScript (SIL) installed. Thanks!
