Jira not restarting
Fr0zt
September 11, 2018 edited
Hello.
I have a Jira instance running a old version of Jira (v4.4.1).
I have my Jira connected to MySQL 5.0.
It was working ok but when I started my machine it doesn't start.
I checked the logs and I get this:
stdeer.log:
2018-09-11 17:24:17 Commons Daemon procrun stderr initialized
java.lang.NoClassDefFoundError: org/apache/tomcat/util/log/SystemLogHandler
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2389)
at java.lang.Class.getConstructor0(Class.java:2699)
at java.lang.Class.newInstance0(Class.java:326)
at java.lang.Class.newInstance(Class.java:308)
at org.apache.catalina.startup.Bootstrap.init(Bootstrap.java:219)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:391)
Caused by: java.lang.ClassNotFoundException: org.apache.tomcat.util.log.SystemLogHandler
at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
... 7 more
stdout.log:
2018-09-11 17:21:13 Commons Daemon procrun stdout initialized
2018-09-11 17:21:49 Commons Daemon procrun stdout initialized
2018-09-11 17:24:17 Commons Daemon procrun stdout initialized
commons-daemon.log:
[2018-09-11 17:21:13] [info] Commons Daemon procrun (1.0.5.0 32-bit) started
[2018-09-11 17:21:13] [info] Running 'JIRA110918152317' Service...
[2018-09-11 17:21:13] [info] Starting service...
[2018-09-11 17:21:15] [info] Service started in 1437 ms.
[2018-09-11 17:21:15] [info] Run service finished.
[2018-09-11 17:21:15] [info] Commons Daemon procrun finished
[2018-09-11 17:21:49] [info] Commons Daemon procrun (1.0.5.0 32-bit) started
[2018-09-11 17:21:49] [info] Running 'JIRA110918152317' Service...
[2018-09-11 17:21:49] [info] Starting service...
[2018-09-11 17:21:50] [info] Service started in 1062 ms.
[2018-09-11 17:21:50] [info] Run service finished.
[2018-09-11 17:21:50] [info] Commons Daemon procrun finished
[2018-09-11 17:24:17] [info] Commons Daemon procrun (1.0.5.0 32-bit) started
[2018-09-11 17:24:17] [info] Running 'JIRA110918152317' Service...
[2018-09-11 17:24:17] [info] Starting service...
[2018-09-11 17:24:18] [info] Service started in 1078 ms.
[2018-09-11 17:24:18] [info] Run service finished.
[2018-09-11 17:24:18] [info] Commons Daemon procrun finished
do you have any idea how is Jira not starting?
Gonchik Tsymzhitov
 Hi!
Have you check your running script after mysqld run it, and under correct user run as?
Gonchik Tsymzhitov
Fr0zt
Can you explain please? I didn't understand.
Gonchik Tsymzhitov
Hi!
I mean check service script:
https://www.digitalocean.com/community/tutorials/how-to-configure-a-linux-service-to-start-automatically-after-a-crash-or-reboot-part-2-reference
As I understand correctly your Jira works good, only after reboot. Hence the issue is incorrect service run scripts.
Gonchik Tsymzhitov
