Jira over HTTPS not starting
Hyd3k
Hi I just followed a tutorial:
https://confluence.atlassian.com/adminjiraserver/running-jira-applications-over-ssl-or-https-938847764.html
Also paid special attention to "
org.apache.coyote.http11.Http11NioProtocol
" parameter I noticed there was a bug in previous versions, but no luck , when I start Jira and try to access in the browser I get nothing, unable to connect seems Jira is not starting properly, I checked common errors but none of them appear in Catalina.out
Is there anybody with the same issue that may help?
Jira version 7.6.2 x64 on CentOS 7x64 minimal updated
Server Hardware: 10 cores, 16GB RAM, 100GB HDD
Hyd3k
January 8, 2018 edited
Once I fixed the SSL chain issue, warning just disappear, it worked like a charm, thank you very much.
Hyd3k
@Gonchik Tsymzhitov I guess your answer fixed this, thank you very much.
Hyd3k
Well Now I tried a clean full installation but this time I first completed DB and first run with Jira then added SSL now it seems to works, but now I have a new question...
SSL certificate is considering as self signed and I did imported root and CA and also domain crt from vendor how can I update self cert and make it use vendor crt so no warning comes out?
Hyd3k
Hmm I created a new keystone new cert everything from clean seems now SSL detects a valid crt.
Hyd3k
After checking full website I noticed in troubleshooting and support tools the following alert:
Warning Supported Platforms
Warning Gadget feed URL
I updated base URL to https://domain:8443 but I still have that warning, any advise how to fix it and show it green/ok?
Gonchik Tsymzhitov
Well, Do you have reverse proxy?
Could you check chain in your certificate?
For example:
https://whatsmychaincert.com/?community.atlassian.com
Hyd3k
Hi, no reverse proxy.
there is something miss configured in the chain , I’ll fix the chain.
any idea about gadged warning?
i disabled ssl and used standard port 8080 and the warning still there.
Gonchik Tsymzhitov
Hi!
Could you provide the connector settings?
And any exceptions or errors in catalina.out?
Gonchik Tsymzhitov
Hyd3k
January 7, 2018 edited
Added following text to
/opt/atlassian/jira/atlassian-jira/WEB-INF/web.xml
<security-constraint>
        <web-resource-collection>
                <web-resource-name>all-except-attachments</web-resource-name>
                <url-pattern>*.jsp</url-pattern>
                <url-pattern>*.jspa</url-pattern>
                <url-pattern>/browse/*</url-pattern>
                <url-pattern>/issues/*</url-pattern>
        </web-resource-collection>
        <user-data-constraint>
                <transport-guarantee>CONFIDENTIAL</transport-guarantee>
        </user-data-constraint>
</security-constraint>
Also edited server.xml
<Connector port="8080"
                   maxThreads="150"
                   minSpareThreads="25"
                   connectionTimeout="20000"
                   enableLookups="false"
                   maxHttpHeaderSize="8192"
                   protocol="HTTP/1.1"
                   useBodyEncodingForURI="true"
                   redirectPort="8443"
                   acceptCount="100"
                   disableUploadTimeout="true"
                   bindOnInit="false"/>
<Connector port="8443" protocol="org.apache.coyote.http11.Http11NioProtocol"
              maxHttpHeaderSize="8192" SSLEnabled="true"
              maxThreads="150" minSpareThreads="25"
              enableLookups="false" disableUploadTimeout="true"
              acceptCount="100" scheme="https" secure="true"
              sslEnabledProtocols="TLSv1,TLSv1.1,TLSv1.2,TLSv1.3"
              clientAuth="false" sslProtocol="TLSv1,TLSv1.1,TLSv1.2,TLSv1.3" useBodyEncodingForURI="true"
              keyAlias="jira" keystoreFile="/var/atlassian/application-data/jira/jira.jks" keystorePass="changeit" keystoreType="JKS"/>
Hyd3k
Hyd3k
Hyd3k
Hyd3k
Hyd3k
When I try to open http://mywebsite:8080 it redirects to https://mywbsite:8443 but screen is empty and keep loading , timeout at the end. Firewall is down.
Just as additional comment, this is a fresh installation, I never completed DB configuration, I wanted to do it through HTTPS but I am stocked here no Jira website loaded...
