Jira post error - expecting comma to separate OBJECT entries
srinivasan radhakrishnan
May 2, 2013
I am trying to use the below code to create new project issue in my jira,
using System.Text;
using System.Net.Http;
using System.Json;
using System.Web.Script.Serialization;
namespace Test
    class Class1
        public void CreateIssue()
            string message = "Hai \"!Hello\" ";
            string data = "{\"fields\":{\"project\":{\"key\":\"TP\"},\"summary\":\"" + message +    "\",\"issuetype\":{\"name\": \"Bug\"}}}";
            System.Net.Http.HttpClient client = new System.Net.Http.HttpClient();
            client.DefaultRequestHeaders.ExpectContinue = false;
            client.Timeout = TimeSpan.FromMinutes(90);
            byte[] crdential = UTF8Encoding.UTF8.GetBytes("adminName:adminPassword");
            client.DefaultRequestHeaders.Authorization = new System.Net.Http.Headers.AuthenticationHeaderValue("Basic", Convert.ToBase64String(crdential));
            client.DefaultRequestHeaders.Accept.Add(new System.Net.Http.Headers.MediaTypeWithQualityHeaderValue("application/json"));
            System.Net.Http.HttpContent content = new StringContent(data, Encoding.UTF8, "application/json");
            try
                client.PostAsync("http://localhost:8080/rest/api/2/issue",content).ContinueWith(requesTask=>
                    try
                        HttpResponseMessage response = requesTask.Result;
                        response.EnsureSuccessStatusCode();
                        response.Content.ReadAsStringAsync().ContinueWith(readTask =>
                            var out1 = readTask.Result;
                    catch (Exception exception)
                        Console.WriteLine(exception.StackTrace.ToString());
                        Console.ReadLine();
            catch (Exception exc)
It throws the issue like below:
"{\"errorMessages\":[\"Unexpected character ('!' (code 33)): was expecting comma to separate OBJECT entries\\n at [Source: org.apache.catalina.connector.CoyoteInputStream@1ac4eeea; line: 1, column: 52]\"]}"
But i use the same json file in Firefox Poster , i have created the issue.
Json file : {"fields":{"project":{"key":"TP"},"summary":"Hai \"!Hello\" ",\"issuetype\":{\"name\": \"Bug\"}}}"
Penny Wyatt (On Leave to July 2021)
May 12, 2013
The issue is that you are not JSON-encoding the message when concatenating it into the string.
This line of Java:
Will put this value into memory:
Hai "!Hello"
And hence this line of Java:
{"fields":{"project":{"key":"TP"},"summary":"Hai "!Hello"","issuetype":{"name": "Bug"}}}
You can see there's a syntax error there in the summary part - the double quotes inside the message are breaking your JSON.
Rather than generating JSON by string concatenation, which is pretty much guaranteed to give you functionality and security issues, I recommend using a JSON library instead. We use Jersey in JIRA but any would do.
