Jira redirecting to http://jiralockederror/
Zsolt Szilagyi November 6, 2013
after I imported some dozen(!) Tasks from Mantis Jira stopped responding - I got gateway timeouts for every call.
So I went to shell and restarted Jira - ar at least I tried. Now whenever I try to open jira from the browser, I get redirected to http://jiralockederror/
Since during restart it complained about a omcat process already running i terminated - later hard killed - the pid.
Setup: Clean Ubuntou10.04 LTS install with nothing but plesk, mysql, Jira + Agile and Confluence.
I have currently 3 Projects with a total of about 50 Tasks. (Just started Migration)
My vServer has 4 GB RAM, currently used are 900mb.
Thanks for any advice.
root@xxx:~# /opt/atlassian/jira/bin/shutdown.sh
[ascii art]
      Atlassian JIRA
      Version : 6.1.2
Detecting JVM PermGen support...
PermGen switch is supported. Setting to 384m
If you encounter issues starting or stopping JIRA, please see the Troubleshooting guide at http://confluence.atlassian.com/display/JIRA/Installation+Tro
Server startup logs are located in /opt/atlassian/jira/logs/catalina.out
Using CATALINA_BASE:   /opt/atlassian/jira
Using CATALINA_HOME:   /opt/atlassian/jira
Using CATALINA_TMPDIR: /opt/atlassian/jira/temp
Using JRE_HOME:        /opt/atlassian/jira/jre/
Using CLASSPATH:       /opt/atlassian/jira/bin/bootstrap.jar:/opt/atlassian/jira/bin/tomcat-juli.jar
Using CATALINA_PID:    /opt/atlassian/jira/work/catalina.pid
PID file found but no matching process was found. Stop aborted.
root@xxx:~# /opt/atlassian/jira/bin/startup.sh
[ascii art]
      Atlassian JIRA
      Version : 6.1.2
Existing PID file found during start.
Removing/clearing stale PID file.
4 votes
Andre Lehmann
November 6, 2013
try to remove the tomcat work-directory (jira-install/work/*) and also remove the jira-home/plugins/.bundled-plugins and jira-home/plugins/.osgi-plugins/
than start Jira. It should create and reset all bundled plugins (like the issue-navigator).
3 votes
Tarun Sapra
November 6, 2013
1) Stop jira
2) follow the instructions here -->https://confluence.atlassian.com/display/JIRAKB/JIRA+is+Locked
3) Restart and REINDEX.
Kakani Sreekanth
January 3, 2016
Thanku
francis
Euroxid,
I'm bumping also into this one yesterday. I installed JIRA service desk, and since then no joy anymore. Removing caches, indexes, bundled_plugins, osgi_plugins and so on didn't help.
So I cleared the database, brought up JIRA, imported an xml backup from the day before yesterday, and JIRA is humming happy again.
Not sure it is related to service desk but looks like it.
Francis
Thank you so much for pointing me to the logfile. It reports the Issue navigator beeing the culpit.
As I was deinstalling some plugins yesterday, I might have kicked that one.
So - how to get it back?
(I will try Taruns approach in a moment.)
JIRA 6.1.2 build: 6157 started. You can now access JIRA through your web browser.
2013-11-06 22:34:45,984 localhost-startStop-1 FATAL      [atlassian.jira.startup.JiraStartupLogger]
The following plugins are required by JIRA, but have not been started: Atlassian JIRA - Plugins - Issue Navigation (com.atlassian.jira.jira-issue-nav-plugin)
2013-11-06 22:34:45,985 localhost-startStop-1 FATAL      [atlassian.jira.upgrade.UpgradeLauncher] Skipping, JIRA is locked.
2013-11-06 22:34:45,987 localhost-startStop-1 INFO      [atlassian.jira.scheduler.JiraSchedulerLauncher] JIRA Scheduler not started: JIRA startup checklist failed.
2013-11-06 22:34:45,996 localhost-startStop-1 WARN      [atlassian.jira.startup.JiraStartupLogger]
___ FAILED PLUGIN REPORT _____________________
1 plugin failed to load during JIRA startup.
        'com.atlassian.jira.jira-issue-nav-plugin' - 'Atlassian JIRA - Plugins - Issue Navigation'  failed to load.
                Application context initialization for 'com.atlassian.jira.issue-nav-plugin' has timed out
                It has the following missing service dependencies :
                         &searchContextHelper of type (objectClass=com.atlassian.jira.components.query.SearchContextHelper)
                         &searcherService of type (objectClass=com.atlassian.jira.components.query.SearcherService)
                         &userSearchModeService of type (objectClass=com.atlassian.jira.components.query.util.UserSearchModeService)
                It was loaded from /var/atlassian/application-data/jira/plugins/.bundled-plugins/jira-issue-nav-plugin-6.1.10.jar
1 plugin are unaccounted for.
Unaccounted for plugins load as artifacts but fail to resolve into full plugins.
        'com.atlassian.jira.jira-issue-nav-components' - 'jira-issue-nav-components'  is unaccounted for.
                It was loaded from /var/atlassian/application-data/jira/plugins/installed-plugins/jira-issue-nav-components-6.2.11.jar
2013-11-06 22:34:46,270 localhost-startStop-1 ERROR      [jira.web.dispatcher.JiraWebworkActionDispatcher]
JIRA startup failed, JIRA has been locked.
2013-11-06 22:34:48,559 Modification Check:thread-1 INFO      [atlassian.jira.startup.JiraStartupLogger]
___ Modifications ___________________________
     Modified Files                                : jira-application.properties
     Removed Files                                 : None
Hello again,
thank you so far. I removed both plugin-directories and emptied the working directory. Additionally I restarted the server and grepped for jira lockfiles. Even so problem remains.
So I set up an On Demand-Jira and imported my last backup (those zipped xml). This instacne does start, but whenever I try to search or browse my issues I get 404. So the problem is clearly with the issue navigator. Anyone ever heard of that?
Best regards
Peter Van de Voorde
November 6, 2013
Hi ,
Did you check your Jira log files?
they can be found in your Jira Home/log directory.
What do they say?
Best regards,
Peter
