Sign up Log in
Jira reduce logging for namespace
Avinash Singh
We have recently integrated Okta and Jira, however since then we see lots of INFO messages logged to the log files.
Eg.
2018-10-17 09:36:51,114 http-nio-8080-exec-24 INFO myUserName 576x4996x1 1jgqvvw 10.1.244.10 /rest/analytics/1.0/publish/bulk [c.a.j.authenticator.okta.OktaJiraAuthenticator30] Authentication result=USER_ALREADY_LOGGED_IN
I have marked this logs namespace to only log on ERROR but this doesnt make any difference.
https://jiratest.xxx.co.xx/secure/admin/ViewLogging.jspa
c.a.j.authenticator.okta.OktaJiraAuthenticator30 ERROR
How do we only log on ERROR?
4 votes
Rambabu Patina _Appfire_
October 17, 2018
Hi @Avinash Singh,
Did you provided the full package name in the 'Package Name' field on enabling log for ERROR event.
Like.. com.atlassian.jira.authenticator.okta.OktaJiraAuthenticator
To set the logging level permanently you can follow the below steps:
1) configuring the log4j.properties file, located in the $JIRA_INSTALL/atlassian-jira/WEB-INF/classes/ directory
2) Add the property: like..
log4j.logger.com.atlassian.jira.authenticator.okta.OktaJiraAuthenticator = ERROR, console, filelog
3) Restart the Jira to pick up the changes.
Ram.
Avinash Singh
Thanks Rambabu.
Isnt c.a.j.authenticator.okta.OktaJiraAuthenticator30 the full package name from the logs?
I cant restart the server at the moment, so I would need to do it through Jira Logging and Profiling admin section.
October 17, 2018
It is not a full package name. First three names shorthanded in the log file.
Can you enable ERROR log using the below package name and let us know how it goes.
Avinash Singh
Excellent that did the job. Is there a way to identify the full package name or did assume that from the log message ?
October 17, 2018
We can identify based on the type of apps we are integrating with Jira. Sometimes may assumptions do the job.
If you feel like my answer helped you, kindly mark my answer as accepted.
Florian Luber April 27, 2021
This package name did not work for me, so I used
log4j.logger.com.atlassian.jira.authenticator.okta.OktaJiraAuthenticator30 = ERROR, console, filelog
(copied from tony wong's suggestion).
Thank you,
Florian
tony wong July 21, 2020
Another way to configure this temporarily is go to
1. Login as Administrator
2. System -> logging and profiling
3. Configure logging level for another package
    -Add the following  "com.atlassian.jira.authenticator.okta.OktaJiraAuthenticator30"
    -Set to OFF.
As mentioned this doesnt' persist, but for temporary debugging this works.
JCFP Admin March 31, 2021
It's work on my instance.
Thanks Tony
Alex Gay
April 27, 2021
To exclude the okta spam in the log files:
Stop the application
Go to:  /atlassian/jira/atlassian-jira/WEB-INF/classes
edit: log4j.properties
add:
# reduce okta logs
log4j.logger.com.atlassian.jira.authenticator.okta = ERROR, console, filelog
Start the application
Alex Gay
January 20, 2021
somebody has an idea on the okta package name for Confluence?
Will it be that simple to replace jira with confluence?
Register Now
Upcoming Jira Events
