Jira report property set default value dynamically
Peter Csiba
February 26, 2012
I want to dynamically set the default value of a property in my report plugin. In particular I want to set it as currentProject* (last project viewed by user). Sample code:
 <property>
                <key>projectid</key>
                <name>report.cs.project</name>
                <description>report.cs.project.description
                </description>
                <type>select</type>
                <values class="com.atlassian.jira.portal.ProjectValuesGenerator"/>
                <default>???</default>
 </property>
Is there any
--direct (set the default value) or
--indirect way (custom property, custom ValuesGenerator,...) to achieve it?
Thank you in advance,
Peter.
Note: a similar question was asked on atlassian forums.
* should be as in API
Bart Gottschalk December 26, 2012
Did you ever get an answer to this? I'm trying to do the exact same thing.
Naren, thanks for the quick response. I decided to implement like this:
package ****;
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.project.Project;
import com.atlassian.jira.portal.ProjectValuesGenerator;
import com.atlassian.jira.ManagerFactory;
import com.atlassian.jira.security.JiraAuthenticationContext;
import com.atlassian.jira.security.Permissions;
import com.atlassian.jira.user.UserProjectHistoryManager;
import com.opensymphony.user.User;
import org.apache.commons.collections.map.ListOrderedMap;
import org.apache.log4j.Logger;
import org.ofbiz.core.entity.GenericValue;
import java.util.Collection;
import java.util.HashMap;
import java.util.Map;
public class MSIProjectValuesGenerator extends ProjectValuesGenerator {
    private static final Logger log = Logger.getLogger(MSIProjectValuesGenerator.class);
    public Map&lt;String, String&gt; getValues(final Map params)
        final User u = (User) params.get("User"); // BUG this user is wrong - the params are being cached somewhere.
        try
            final Collection&lt;GenericValue&gt; projectGVs = ManagerFactory.getPermissionManager().getProjects(Permissions.BROWSE, u);
            final Map&lt;String, String&gt; projects = ListOrderedMap.decorate(new HashMap&lt;Long, String&gt;(projectGVs.size()));
            JiraAuthenticationContext authenticationContext = ComponentAccessor.getJiraAuthenticationContext();
            com.atlassian.crowd.embedded.api.User loggedInUser = authenticationContext.getLoggedInUser();
            UserProjectHistoryManager userProjectHistoryManager = ComponentAccessor.getComponentOfType(UserProjectHistoryManager.class);
            Project selectedProject = userProjectHistoryManager.getCurrentProject(10, loggedInUser);
        	//log.info("projects is " + projects);
        	projects.put(selectedProject.getId().toString(),selectedProject.getName());
            for (final Object element : projectGVs)
                final GenericValue project = (GenericValue) element;
            	//log.info("project.getLong(\"id\").toString() is " + project.getLong("id").toString());
                projects.put(project.getLong("id").toString(), project.getString("name"));
            return projects;
        catch (final Exception e)
            log.error("Could not retrieve project values for this user: " + u.getName(), e);
            return null;
Naren
December 27, 2012
Well, the below code works for me, you may like to give a try -
import java.util.List;
import com.atlassian.configurable.ValuesGenerator;
import com.atlassian.crowd.embedded.api.User;
public class ProjectValuesGenerator implements ValuesGenerator {
	private static final Logger log = Logger.getLogger(ProjectValuesGenerator.class);
	@Override
	public Map&lt;String, String&gt; getValues(Map map) {
Map&lt;String, String&gt; params = new HashMap&lt;String, String&gt;();
//Get the project
params.put(selectedProject.getId().toStrin (),selectedProject.getName());
return params;
Shantonu Hossain November 26, 2013
Does the code actually show you a single project? I am trying to so the same thing but my code lists all the projects in JIRA not the selected project. Did you change anything to atlassian-plugin.xml?
Naren
December 26, 2012
You need to write your own custom ProjectValuesGenerator which will extend the JiraWebActionSupport class override the getSelectedProject() and you must implement ValuesGenerator.
Alternatively, you can also use the method getCurrentProject(int permission, com.atlassian.crowd.embedded.api.User user) of UserProjectHistorymanager interface.
params.put(selectedProject.getId().toString(),selectedProject.getName());
Hope this should help you!
