Jira rest api issue export with cookie authentication returns 401
Deleted user December 6, 2019 edited
Dear community,
im actually writing an exporter for all project issues in java using cookie authentication.
In the end, i want to safe all json data to a file i did get.
Problem: I do constantly receive http 401 as i use my session id (received from basic auth. before) as my cookie variable.
I did make sure that the syntax of my cookie is correct, so there have to be another detail i have missed. So my jsonData at the end of code still remains empty. Is another authentication needed?
I have full access to the project and everything else works fine.
<...> placeholder
output:
loginResponse:
{"session":{"name":"JSESSIONID","value":"3CA6985D902FEEB7FA5A79FF6E570218"},"loginInfo":{"failedLoginCount":6,"loginCount":130,"lastFailedLoginTime":"2019-09-16T15:02:49.185+0200","previousLoginTime":"2019-12-06T09:17:35.689+0100"}}
JSessionID:
https://<baseurl>.com/jira/rest/api/2/search?jql=project="<projectname>"&username=<username>
401
jsonData:
SUCCES!
code:
public static String parseJSessionID(String input) {
String jSessionID = "";
try{
JsonElement parser = new JsonParser().parse(input);
Object obj = parser.getAsJsonObject();
JsonObject jsonObject = (JsonObject) obj;
JsonObject sessionJsonObj = (JsonObject) jsonObject.get("session");
jSessionID = (String) sessionJsonObj.get("value").toString();
} catch (Exception ex){
System.out.println("Error in parseJSessionID: " + ex.getLocalizedMessage());
jSessionID = "ERROR";
System.out.println("\nJSessionID: ");
System.out.println(jSessionID);
return jSessionID;
public static String getJsonData(String baseURL, String jSessionID, String loginUserName) {
String jsonData = "";
try {
URL url = new URL(baseURL + "api/2/search" + "?jql=project=\"<projectname>\"" + "&username=" + loginUserName);
System.out.println(url.toString());
System.out.println("\n");
String cookie = "JSESSIONID=" + jSessionID;
HttpURLConnection conn = (HttpURLConnection) url.openConnection();
conn.setRequestMethod("GET");
conn.setRequestProperty("Content-Type", "application/json");
conn.setRequestProperty("Cookie", cookie);
System.out.println(conn.getResponseCode());
if(conn.getResponseCode() == 200) {
BufferedReader br = new BufferedReader(new InputStreamReader(conn.getInputStream()));
String output = "";
while((output = br.readLine()) != null) {
jsonData += output;
conn.disconnect();
} catch (Exception ex) {
System.out.println("Error in getJsonData: " + ex.getLocalizedMessage());
jsonData = "ERROR";
Register here ⬇️
