Jira shows ssl certificate not secure in Chrome
Fabio Manzoni
Hi Guys,
I have a valid certificate and Jira shows Not Secure in Chrome and Firefox.
Sometimes, when I open the Jira url the certificate show right, but after open a project or dashboard problems occour again.
Can someone help me?
Leonardo De Almeida
May 20, 2020
Hello everyone!
My name is Leonardo, I'm a Cloud support engineer at Atlassian.
I stumbled into this thread while doing some research, so I wanted to share my findings.
There does not seem to have any effective security risk. But, what happens is that when you are on an Agile board view for example, Jira is loading a non HTTPS resource in the page, which triggers that warning:
I found that when inspecting the browser console upon the page's loading. That URL takes you nowhere, it just returns a 404. If I have to make an assumption, I would say that it can be a legacy resource present in the code, or something of that sort. But that is just my assumption.
I have reported a bug to have that content reviewed: https://jira.atlassian.com/browse/JSWCLOUD-18958
Of course, I cannot give any ETA as to when someone will look into it, but at least we have our devs be aware.
Leonardo De Almeida
May 20, 2020
Well,
I probably was hasty on this one...
I did not notice the Jira Server tags, so I don't believe my findings will apply to your case.
Apologies for the inconvenience!
Like Fabio Manzoni likes this
Brian Pelton
Thank you Leonardo, this helped me fix my issue. I was accidentally referencing a custom priority icon over http instead of https from my jira cloud instance.
I use the developer tools to discover this and fixed it.
A good tip to anyone seeing those Not Secure warnings on how to find the possible cause.
Cristiano Mariano
January 24, 2020
Hi @Fabio Manzoni ! How are you doing?
Looks like your Base URL is set to http:// instead of https://. Would you please check that?
If it is wrong, it will (as you said) work as expected as long as you do not click any link.
Hope this helps!
Fabio Manzoni
Hi Cristiano,
The url is https://
Cristiano Mariano
January 27, 2020
In fact, I mean the Jira Base URL configuration.
To check it, just click the Cog Icon in the top bar, then System. Under General Settings you will see the Base URL property. It should be the same URL that you are using to access the application.
Fabio Manzoni
Hi Cristiano,
I checked this and it's correctly. In fact this started to occur after a Chrome update. I didn't any change in my Jira Instance.
Anas Zakariyah
April 30, 2020
I also have the same issue.
Navigating dashboard is okay. It show Secure.
But when opening and navigating project, it shows Not Secure.
