Sign up Log in
Jira stopped. Now can't start
Nav
Hello
The jira was configured and working fine till yesterday but it now stopped and can't start again. Here is the error message when I tried to start
Server startup logs are located in /opt/atlassian/jira/logs/catalina.out
Using CATALINA_BASE:   /opt/atlassian/jira
Using CATALINA_HOME:   /opt/atlassian/jira
Using CATALINA_TMPDIR: /opt/atlassian/jira/temp
Using JRE_HOME:        /opt/atlassian/jira/jre/
Using CLASSPATH:       /opt/atlassian/jira/bin/bootstrap.jar:/opt/atlassian/jira/bin/tomcat-juli.jar
Using CATALINA_PID:    /opt/atlassian/jira/work/catalina.pid
Existing PID file found during start.
Unable to read PID file. Start aborted.
Thansk for looking into this.
21 votes
Nav
April 10, 2017 edited
Thanks Sam for quick revert. I really appreicate your help. Finally I am able resolve the issue. I am posting answer here so it may help someone else with same problem.
Goto: /opt/atlassian/jira/work/ directory and delete catalina.pid file. ( Due to some strange reason, the pid proces was killed but file not removed)
stop and start jira again and it works.
Dale_K_M_Tan
July 21, 2018
Found this while trying to get my Confluence instance to start too. Thanks for asking!
Anton Perera March 4, 2019
@Nav Thanks for the answer. This fixed my issue too. :)
gadadechhaya28 May 24, 2019
Hi @Nav ,
I followed the same procedure,deleted /opt/atlassian/jira/work/catalina.pid file....but still not able to start jira
Like Alexander Samets likes this
Shirley Shorter June 15, 2019
Thanks it worked for me too Linux on CentOS 6 :)
Roger L. Main
July 16, 2019
Worked for me!
Brik_ Oussama
March 4, 2025
Greeeeat, thanks a lot. Worked for me (confluence).
Sam Hall
Hi Nav,
What command are you using to start JIRA?
The 'Existing PID file found during start' message inticates there might be reminants of existing JIRA/tomcat process that you need to kill/remove.
Also, take look at this thread, which is a similar (but not exactly the same) problem. The answers from Brian Jones and Nic Brough might help.
Nav
Hi Sam
Thanks for the quick revert.
I use any one of these commands to start Jira. It worked until today.
service jira start
OR
/opt/atlassian/jira/bin/./start-jira.sh
 I had looked at this thread earlier but it wouldn't help as question from eiger3970 thread snippet tells secific existing PID number but in my case it says later 'Unable to read PID file'.
I see messaging coming from catalina.sh.
Nav
Also when I try to stop the jira ( assume PID still running), it says
 "PID file found but no matching process was found. Stop aborted"
Like Amy Lucht likes this
Sam Hall
The general advice on the other thread about checking for running processes and killing them is really what I was referring to. I spotted that the snippet showed slighlty different error from yours.
Anyway, have a look at this Knowledge Base article, particuarly the diagnosis part, and see if it helps you fix.
https://confluence.atlassian.com/jirakb/the-jira-application-doesn-t-terminate-after-shutdown-script-is-executed-222200632.html
Also, take note of the info in the admin users guides about starting/stopping JIRA (assuming you are on JIRA v7) as there are different commands depending on whether you installed JIRA as a service or not:
https://confluence.atlassian.com/adminjiraserver073/start-and-stop-jira-applications-861253944.html
p.s. I edited your replies above to remove blank space.
Register Now
Upcoming Jira Events
