Jira stopped authenticating with active directory
Daniel Silva
Jira has stopped authenticating active directory users (including the user with administrator privileges).
No access to Jira, just AD, how can I solve this?
Kind Regards
Tansu Akdeniz
December 27, 2019
Hi @Roberto Miasack ,
There should be an internal user with admin rights. Can you please check it?
If you don't know the credentials, you can restore it by following these steps.
Regards
Daniel Silva
Hi, Tansu.
Thanks for the quick response.
I don't have internal user access so I'm following the steps you sent me.
Anyway, I can't create the recovery_admin user. Could you help me validate if the sevenv.bat file is correctly edited?
Regards
Tansu Akdeniz
December 27, 2019
You don't have to create a recovery_admin user. It will be automatically eligible to login after following the steps in KB.
Daniel Silva
I add this setence is the last line?
-Datlassian.recovery.password=<your-password>
Tansu Akdeniz
December 27, 2019
That's right.
Daniel Silva
I can't login to recovery_admin.
brbojorque
December 27, 2019
Hi @Roberto Miasack  since your server is Windows.
Please follow the command to open the Properties window of Java in this link. (Please see the Windows Service instruction specifically)
https://confluence.atlassian.com/adminjiraserver/setting-properties-and-options-on-startup-938847831.html?Settingpropertiesandoptionsonstartup-Windowsservice
After that follow the link @Tansu Akdeniz added in his answer.
This time add the
 Into the Java tab in the Tomcat settings in the Windows Service.
Restart Jira via Windows Services (services.msc)
Try the password you have specified
Daniel Silva
Hi, Bryan.
I already did what you quoted above. I still can't authenticate with recovery_admin.
brbojorque
December 27, 2019 edited
@Roberto Miasack
Please follow the content of the link.
https://confluence.atlassian.com/adminjiraserver/setting-properties-and-options-on-startup-938847831.html#Settingpropertiesandoptionsonstartup-Windowsservice
You need to do a series of commands just to get the JAVA options and put the arguments in that window.
Remember to restart Jira.
Daniel Silva
Bryan,
Thank you for answer me.
But, i could not reproduce. I do not know where I am going wrong in the steps, but this recovery_admin does not work.
If there is any other way to help me, i appreciate.
Kind Regards,
brbojorque
December 27, 2019
Please visit this link and check if the Database operations is applicable to your case.
  • It will find the existing user you have in the Internal Directory
  • It will reset the user to a known password.
  • Make sure you change it afterwards.
https://confluence.atlassian.com/jira/retrieving-the-jira-administrator-192836.html
atlassian, atlassian community, loom ai, atlassian loom ai, loom, atlassian ai, record recaps of meetings, meeting recaps, loom recaps, share meeting recaps,
Loom’s guide to great meetings 📹
Register today!
