We have recently upgraded the jira and now have some problems.
Some custom fields are added late after creating the issue.
Like : Summary and Security Level.
Transitions also appear very late after issue creation.
Jira Version: 8.13.1
As you can see issue created 23 min. ago
Level Updated 18 min. ago
In older version of jira it only took 1 or 2 minute for updating but now it works slowly.
Please help me to fix this problem.
@Jamil Rahimov , are those updates made manually or through automation?
If automation, are you using external scripts with rest api or some postfunctions or automation for JIRA?
Do you generate logs for them?
@Fazila Ashraf
Thank you for your quick response but we already solve this problem.
The problem was on server side
Care to maybe elaborate what the issue was? Perhaps someone else can benefit from it.
@Dirk Ronsmans
We had problem with CPU.
It worked fine after closing unnecessary apps which consume cpu.
