×Hi,
How can i do the Jira Upgrade with SSL, because i have already configured Jira with HTTPS, Do i need to create the certificates again or i can copy the existing certificates to upgraded instance.
You can re-use the existing certificates. You will need to re-install them, the upgrades remove the old cacerts file and command line parameters (later versions of the installers will tell you what files they've amended)
Thank you for the replay. Do i need to follow the same procedure for installing the certificate.
Yes, it's the same procedure.
Thanks, After upgrading to 7.5.0 the Application Navigator is not working, it it because of certificate issue
