Jira-user unable to edit/delete his own comments
rambabu patina
June 30, 2015
The jira-user has the rights to edit his own comments and delete own comments. When he try to edit the comments on closed issue he was unable to edit/delete the comment. We have enabled property "jira.issue.editable" flag set to true on close Status. Why can't he able to edit/delete his own comment on the closed issue? Could you please provide me the workaround/solution for this problem.
Quick answer most appreciated.
Patina
petry
June 30, 2015
Based on this doc, can you check if this customer has the "Delete Own Comments" permission in this project?
Also, as an Admin, go to the issue, click on "Admin > Permission Helper" and check the permissions of that specific user to delete own comments.
Hope it helps!
Andre
Sateesh Chandra
June 30, 2015
Try removing the property completely from the workflow and try
rambabu patina
June 30, 2015
We cannot remove the workflow properties. Why because we have been maintaining these from long back.
Nic Brough -Adaptavist-
June 30, 2015
You need to remove them to test if they are the problem.
June 30, 2015
Do you have other properties sset on that status?
Can he edit or delete comments on other issues in the same project?  Are they in different status?
rambabu patina
June 30, 2015
Hi Nic, We set "jira.issue.editable" flag true on closed issue for jira-admins and current assignee only. And he was able to edit/delete other issues (same type in same project). But the particular issue is not. Thanks, Patina
rambabu patina
June 30, 2015
I am using JIRA 6.3.15 version
