You can use the Jira User Export app for Jira Server. It is free to download and use: https://marketplace.atlassian.com/apps/1220535/jira-user-export?hosting=server&tab=overview
Regards
Lasse Langhorn
Depends on what access you have and what you need. Are you a Jira admin? Do you have read access to the database? (If the answer to both of those is "no", then you probably can't do it anyway)
Jira in question is old 4.0 upgraded from 3.xx
it still old userbase+membershipbase etc.
OK - the table structure was pretty ugly back then :(
For username and full name run this:
select username, psfn.propertyvalue as full_name from userbase u join propertyentry pefn on pefn.entity_id = u.id and pefn.ENTITY_NAME = 'OSUser' and pefn.property_key = 'fullName' join propertystring psfn on psfn.id = pefn.id
If you want the email address as well, do this:
select username, psfn.propertyvalue as full_name, psem.propertyvalue as email from userbase u join propertyentry pefn on pefn.entity_id = u.id and pefn.ENTITY_NAME = 'OSUser' and pefn.property_key = 'fullName' join propertystring psfn on psfn.id = pefn.id join propertyentry peem on peem.entity_id = u.id and peem.ENTITY_NAME = 'OSUser' and peem.property_key = 'email' join propertystring psem on peem.id = psem.id
For DB schema see https://developer.atlassian.com/display/JIRADEV/Database+Schema
Note that the user table changed in v4.3, so if you are on v4.2 or earlier see http://confluence.atlassian.com/display/JIRA040/Database+Schema#DatabaseSchema-UsersandGroups
I am looking to get list of inactive users from OSUser, like this (for confluence): http://alturl.com/3qov8
