JiraHelper in more than one ContextProvider
Jorge Jerez
I'm using two web panels in the Issue Screen, they are totally different.
They have to load depending of the project, so i use JiraHelper.getProject()
In the first panel, it works fine, jiraHelper contains the project.
But in the other, jiraHelper project is null, I saw it with Debug options.
This is making only one of my panels load, but i need both.
Sven Jerat
April 3, 2019
You can try to make a try / catch block around your code.
try {
projectId = jiraHelper.getProject().getId();
} catch (Exception e) {
log.error(e);
It's working for me. I get a nullpointerexception AND the projectId.
But I didn't understand why!
