Any way to work JSS with JIRA 5.0.6 ?
I've tried to install Quick Edit plugin 1.0.41, 1.0.42 ... till Quick Edit plugin 1.0.52 but JSS still says that it's incompatible with Quick Edit plugin and so the Global Edit Postfunction is not available.
Any solution for this problem?
Kind Regards,
Regina
same with me
I'm also having this issue. I'm on Jira 5.2 with Quick Edit Plugin 1.0.54 trying to use JSS 2.1.2. Does anyone know of a compatible version of these plugins?
Same with me, is this the edit in place plugin which is part of default Jira? I hope not as I do consider it extreamly useful.
Any resolution on this? I am also seeing this Global Edit Validation & Postfunction scripts are disabled due to installation problem: incompatible Quick Edit plugin.
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
