Jql Query?
pokalav
Hi Team,
    I am trying to use JQL filter while retrieving the records from JIRA, and using the following one :
https://jira-domain.com/rest/api/2/search?jql= cf[10002] is not null and cf[15407] = svc.informatica and updated<='2017-12-13 02:12'
Is there a way that I can filter on the child fields like the Comments updated date ? Please advise
Venkatesh.
Tarun Sapra
January 9, 2018 edited
Just store the response in an JSON object and use the "dot" operator to fetch values of respective fields.
pokalav
Hi Tarun,
    Thanks for your update. Could you please elaborate on this?
Venkatesh
pokalav
Is it possible for you to send an example call, that would be of great help.
Alexey Matveev
January 9, 2018
You can not search on the JSON result. You would need to write your own program.
