Hello everyone,
after the update of JIRA to 7.1.9 the following script does not work anymore:
from com.atlassian.jira import ComponentManager
from com.atlassian.jira.security.roles import ProjectRoleManager
result = True
project = issue.getProjectObject()
projectRoleManager = ComponentManager.getComponentInstanceOfType(ProjectRoleManager)
authenticationContext = ComponentManager.getInstance().getJiraAuthenticationContext()
userIsInRoleCustomers = projectRoleManager.isUserInProjectRole(authenticationContext.getUser(), projectRoleManager.getProjectRole("Customers"), project)
userIsInRoleDevelopers = projectRoleManager.isUserInProjectRole(authenticationContext.getUser(), projectRoleManager.getProjectRole("Developers"), project)
issueTypeIsNotSR = issue.getIssueTypeObject().getName() != "Service Request"
if userIsInRoleCustomers:
if not userIsInRoleDevelopers:
if issueTypeIsNotSR:
result = False
description = "You do not have enough permissions to create this Issue Type! Please select - Service Request -"i'm not good in scripting so i need some help for this.
this is the error which occurs:
2016-09-02 12:13:25,408 http-nio-9001-exec-23 ERROR ad 733x2990x1 c7g46g 172.16.177.197,10.0.0.63 /secure/QuickCreateIssue.jspa [c.q.j.plugin.workflow.JythonValidator] Unrecognized exception while executing Jyphon script: null
Traceback (most recent call last):
File "<string>", line 8, in <module>
AttributeError: 'com.atlassian.jira.ComponentManager' object has no attribute 'getJiraAuthenticationContext'
at org.python.core.Py.AttributeError(Py.java:166)
at org.python.core.PyObject.noAttributeError(PyObject.java:930)
at org.python.core.PyObject.__getattr__(PyObject.java:925)
at org.python.pycode._pyx16.f$0(<string>:20)
at org.python.pycode._pyx16.call_function(<string>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.PyCode.call(PyCode.java:18)
at org.python.core.Py.runCode(Py.java:1261)
at org.python.core.Py.exec(Py.java:1305)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:215)
at com.quisapps.jira.plugin.workflow.JythonValidator.validate(JythonValidator.java:51)
at com.atlassian.jira.workflow.SkippableValidator.validate(SkippableValidator.java:45)
at com.opensymphony.workflow.AbstractWorkflow.verifyInputs(AbstractWorkflow.java:1512)
at com.opensymphony.workflow.AbstractWorkflow.transitionWorkflow(AbstractWorkflow.java:1203)
at com.opensymphony.workflow.AbstractWorkflow.initialize(AbstractWorkflow.java:615)
at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:741)
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:580)
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:494)
at com.atlassian.jira.bc.issue.DefaultIssueService.create(DefaultIssueService.java:230)
at com.atlassian.jira.bc.issue.DefaultIssueService.create(DefaultIssueService.java:199)
... 2 filtered
at java.lang.reflect.Method.invoke(Method.java:498)
at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:26)
at com.sun.proxy.$Proxy375.create(Unknown Source)
... 2 filtered
at com.atlassian.plugin.osgi.bridge.external.HostComponentFactoryBean$DynamicServiceInvocationHandler.invoke(HostComponentFactoryBean.java:136)
at com.atlassian.jira.quickedit.action.QuickCreateIssue.doExecute(QuickCreateIssue.java:308)
... 1 filtered
at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:63)
... 7 filtered
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
... 50 filtered
at com.atlassian.greenhopper.jira.filters.ClassicBoardRouter.doFilter(ClassicBoardRouter.java:59)
... 62 filtered
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:70)
... 89 filtered
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
2016-09-02 12:13:25,412 http-nio-9001-exec-23 ERROR ad 733x2990x1 c7g46g 172.16.177.197,10.0.0.63 /secure/QuickCreateIssue.jspa [c.a.j.bc.issue.DefaultIssueService] Error creating issue:
com.atlassian.jira.exception.CreateException: root cause: Traceback (most recent call last):
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:588)
... 2 filtered
... 2 filtered
... 1 filtered
... 7 filtered
... 50 filtered
... 62 filtered
... 89 filtered
Caused by: com.atlassian.jira.workflow.WorkflowException: root cause: Traceback (most recent call last):
at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:760)
Caused by: com.opensymphony.workflow.WorkflowException: root cause: Traceback (most recent call last):
at com.quisapps.jira.plugin.workflow.JythonValidator.validate(JythonValidator.java:89)
... 232 more
Caused by: Traceback (most recent call last):
... 237 more
so what i need to change?
best regards
toni
Swap ComponentManager with ComponentAccessor everywhere. Instead of ComponentManager.getInstanceOfType() use ComponentAccessor.getComponent().
ComponentAccessor is in the com.atlassian.jira.component package.
ok now this error occurs:
2016-09-02 15:24:36,511 http-nio-9001-exec-20 ERROR ad 924x3322x1 1p0lww1 172.16.177.197,10.0.0.63 /secure/QuickCreateIssue.jspa [c.q.j.plugin.workflow.JythonValidator] Unrecognized exception while executing Jyphon script: null
File "<string>", line 1, in <module>
ImportError: cannot import name ComponentAccessor
at org.python.core.Py.ImportError(Py.java:290)
at org.python.core.imp.importFromAs(imp.java:984)
at org.python.core.imp.importFrom(imp.java:954)
at org.python.pycode._pyx20.f$0(<string>:16)
at org.python.pycode._pyx20.call_function(<string>)
... 2 filtered
... 2 filtered
... 1 filtered
... 7 filtered
... 50 filtered
... 62 filtered
... 89 filtered
2016-09-02 15:24:36,517 http-nio-9001-exec-20 ERROR ad 924x3322x1 1p0lww1 172.16.177.197,10.0.0.63 /secure/QuickCreateIssue.jspa [c.a.j.bc.issue.DefaultIssueService] Error creating issue:
... 2 filtered
... 2 filtered
... 1 filtered
... 7 filtered
... 50 filtered
... 62 filtered
... 89 filtered
... 232 more
... 237 more
Did you put the right package for the ComponentAccessor import at the beginning of the script?
ok i miss that. but now:
2016-09-02 15:30:47,983 http-nio-9001-exec-6 ERROR ad 930x3453x1 1p0lww1 172.16.177.197,10.0.0.63 /secure/QuickCreateIssue.jspa [c.q.j.plugin.workflow.JythonValidator] Unrecognized exception while executing Jyphon script: null
AttributeError: type object 'com.atlassian.jira.component.ComponentAccessor' has no attribute 'getInstance'
at org.python.core.PyType.noAttributeError(PyType.java:1715)
at org.python.pycode._pyx24.f$0(<string>:16)
at org.python.pycode._pyx24.call_function(<string>)
... 2 filtered
... 2 filtered
... 1 filtered
... 7 filtered
... 50 filtered
... 62 filtered
... 89 filtered
2016-09-02 15:30:47,989 http-nio-9001-exec-6 ERROR ad 930x3453x1 1p0lww1 172.16.177.197,10.0.0.63 /secure/QuickCreateIssue.jspa [c.a.j.bc.issue.DefaultIssueService] Error creating issue:
... 2 filtered
... 2 filtered
... 1 filtered
... 7 filtered
... 50 filtered
... 62 filtered
... 89 filtered
... 232 more
... 237 more
updated script
from com.atlassian.jira.component import ComponentAccessor
result = True
projectRoleManager = ComponentAccessor.getComponent(ProjectRoleManager)
authenticationContext = ComponentAccessor.getInstance().getJiraAuthenticationContext()
result = False
Use:
ComponentAccessor.getJiraAuthenticationContext()
instead of:
Read the error messages - they give you important pointers about what goes wrong.
I am new to python scripting. When i run, i am getting following import error.
ImportError: No module named com.atlassian.jira.component
How can i fix this? where can i download com.atlassian.jira.component module and install.
Any suggestions much appriciated.
Regards
Jey
hi jey,
you need to paste this into your script to import.
depending on your action you want to execute you will need other packages.
best
toni
I pasted in script
#!/usr/bin/python2.7
from jira import JIRA
and when I run, I get same error
File "./component.py", line 3, in <module>
Should I install any packages?. I have only installed jira using pip install.
pip install jira
Regards
Jey
