KPI Plugin for DC
Juan Du Toit
Hi All,
I am looking for a KPI plugin for Jira Data Centre
We want to be able to create and track KPIs using Jira data, but we also want to create individual KPIs based on roles that are not driven by Jira data.
Are there any suggestions for a good plugin?
Alternatively, any suggestions for a tool that can sync with Jira?
Juan
Ollie Guan
Hi @Juan Du Toit ,
Search keywords in atlassian marketplace, such as "KPI"
Performance Objectives: Charts for Jira
Design Industries June 6, 2023
Thanks, Ollie
It doesn't 100% do What I need to, but we will investigate for our second phase of rolling out KPIs based on Jira data
Tuncay Senturk
I recommend using the Enhancer Plugin for Jira to track your KPI metrics. This plugin offers a variety of custom fields, including user, time, and date fields, which you can use to collect the data you need. The best part is that you only need to install the app, define your custom fields, and reindex Jira, and then you'll have access to metrics for all the issues in your Jira instance, not just the ones that are created in the future.
I'm one of the folks behind this plugin, and I'd be glad to assist.
Thanks, Tuncay
Like • Tuncay Senturk likes this
Tuncay Senturk
You're welcome
Tanya _DevAcrobats_ March 8, 2023
Performance Objectives app is a flexible tool for tracking KPIs in Jira.
You can set your KPIs based on standard Jira metrics and dynamic metrics like 'Time Since', 'Time in Status', 'Time Between', 'Time in Assignee', 'Cycles in Status', 'Cycles in Assignee', etc., that do not exist as data fields in Jira. Thе app also supports Formula and Conditional metrics and offers rich flexibility for setting targets for your KPIs (fixed, % of total, % change, etc.).
As for your second request you may use Zapier to automate import of data in Jira from external systems and once they are in Jira you can use them in your reports in the Performance Objectives app.
There are numerous options to create data groups based on your roles using advanced JQL and Jira automation and then use them as segmentations for your KPIs.
You can check the app's key features on our Marketplace page and follow the links to our website for somе KPI examples and User Guide.
Please note that I am part of the team that developed the app. Our support team will be glad to help with any challenging configurations if you decide to try it.
Tanya
