Kanban Default Screens
lilachFeit October 29, 2016
Hi
When creating a new issue in a kanban project there is no "Due Date" Filed by default.
How can i add it to "Kanban Default Issue Screen" by default? (In my Screens there is just "Default Screen" and there is no "Kanban Default Issue Screen" so from where does it comes from?)
As workaround i currently add the Field  "Due Date" to my project screen manually.
Thanks.
Jobin Kuruvilla [Adaptavist]
October 30, 2016
JIRA adds it programmatically.
An alternative is to create a shared project configuration. When you create the project, instead of selecting the Kanban project blueprint, select the shared configuration of an already setup Kanban project. It will then reuse the screens from that poject, with the "Due Date" field in it. It will also reuse workflows and other shared configurations from that project.
