×When you import from a Bugzilla database is it possible to "keep" the Bugzilla IDs, so that the corresponding JIRA IDs have the same number?? We are migrating from Bugzilla but have a selfwritten subversion connection which links to the Bugzilla IDs. I want to have legacy support so that the IDs in the subversion comments are still valid in the new Jira system.
JIRA Importers Plugin currently stores the original bud id as External System Id which is a custom field. So you can always refer back from the legacy system.
It's not currently possible to re-use the original bug id as issue key in JIRA Importers Plugin for couple of reasons. First the issue key pattern has standarized and many external tools assume that the issue key in JIRA has a known format. Sure there's an advanced option in JIRA to change it, but it may break something.
Also it's not possible to change issue key format for only one project, this is a global setting AFAIR.
If you really want to go this way you can modify JIRA Importers Plugin to copy issue keys, then you'd have to reconfigure JIRA and it may work as expected.
But I'm not sure if it really worth it. You decide.
I'm having the same issue. I wouldn't want to change the format, I just want to translate from one format to another. Is there a way to do that?
We just recently imported Bugzilla Data into our JIRA using the Bugzilla External Import Tool, and we also wanted keep the ID's.
The main reason for us needing the same ID's was to keep the correct links of git-checkins to the bugs through the Jira add-on "git Integration for Jira".
We solved the issue by editing the data direclty on the database using an oracle-sql script.
OK, there might be better ways, but this is how it worked for us...
Prerequisites:
Below are the scripts. They were used on:
There are two major parts:
Usage:
Except for the attachments, everything should now be fine.
Do not drop the table zilla_to_jira_tmp yet, that is still needed for part 2 below.
define PROJECTKEY = 'BUG'; -- Project Key of the Bug-Project set serveroutput on size 100000; create table zilla_to_jira_tmp as select to_number(cfv.stringvalue) BugzillaId, ji2.id IssuePK, ji2.issuenum JiraIssuenum, '&PROJECTKEY-'||ji2.issuenum OldJiraKey, '&PROJECTKEY-'||cfv.stringvalue NewJiraKey from jiraissue ji2 join project p on ji2.project = p.id join customfieldvalue cfv on (ji2.id = cfv.issue) join customfield cf on (cfv.customfield = cf.id and cf.cfname = 'External issue ID') where p.pkey = '&PROJECTKEY'; create unique index zilla_to_jira_tmp_1 on zilla_to_jira_tmp (OldJiraKey); create unique index zilla_to_jira_tmp_2 on zilla_to_jira_tmp (issuepk); -- Update the Issue-Keys with the corresponding Bugzilla ID merge into jiraissue ji using ( select BugzillaId, IssuePK from zilla_to_jira_tmp where BugzillaId != JiraIssuenum ) bz on (ji.id = bz.IssuePK) when matched then update set ji.issuenum = bz.BugzillaId; -- Update the High-Watermark Project Counter with the correct max-value update project p set pcounter = (select max(issuenum) from jiraissue ji join project p1 on ji.project = p1.id where p1.pkey = '&PROJECTKEY') where p.pkey = '&PROJECTKEY'; -- Update all Keys in description and comments to the new value (This part is NOT rerunnable) declare v_counter number := 0; begin -- update old keys in jiraissue descriptions for l_jiraissue in (select * from jiraissue ji join zilla_to_jira_tmp bz on (ji.id = bz.IssuePK) where ji.description like '%&PROJECTKEY-%') loop for l_update in (select to_char(regexp_substr(l_jiraissue.description,'(&PROJECTKEY-[0-9]+)',1,level)) oldKey from dual connect by level <= regexp_count(l_jiraissue.description,'(&PROJECTKEY-[0-9]+)')) loop -- update every bug-number occurrence one at a time: update jiraissue set description = replace(description,l_update.oldKey,(select newjirakey from zilla_to_jira_tmp where OldJiraKey=l_update.oldKey)) where id = l_jiraissue.id; v_counter := v_counter + 1; end loop; end loop; dbms_output.put_line('Updated '||v_counter||' references in bug descriptions'); -- update old keys in all comments (jiraaction) v_counter := 0; for l_action in (select ja.id, ja.issueid,ja.actionbody from jiraaction ja join zilla_to_jira_tmp bz on (ja.issueid = bz.IssuePK) where actiontype = 'comment' and actionbody like '%&PROJECTKEY-%') loop for l_update in (select to_char(regexp_substr(l_action.actionbody,'(&PROJECTKEY-[0-9]+)',1,level)) oldKey from dual connect by level <= regexp_count(l_action.actionbody,'(&PROJECTKEY-[0-9]+)')) loop -- update every bug-number occurrence one at a time: update jiraaction set actionbody = replace(actionbody,l_update.oldKey,(select newjirakey from zilla_to_jira_tmp where OldJiraKey=l_update.oldKey)) where id = l_action.id; v_counter := v_counter + 1; end loop; end loop; dbms_output.put_line('Updated '||v_counter||' references in bug comments'); end; / -- Crosscheck the data with Bugzilla. If OK, commit -- check descriptions and new Jira-Key: select * from ( select bz.BugzillaId,'&PROJECTKEY-'||ji.issuenum NewJiraKey, ji.description NewDescription from jiraissue ji join zilla_to_jira_tmp bz on (ji.id = bz.IssuePK) where ji.description like '%&PROJECTKEY-%' order by IssuePK desc) where rownum < 5; -- check content of comments: select * from ( select bz.BugzillaId, bz.NewJiraKey, ja.actionbody commnt from jiraaction ja join zilla_to_jira_tmp bz on (ja.issueid = bz.IssuePK) where actiontype = 'comment' and actionbody like '%&PROJECTKEY-%' order by IssuePK desc) where rownum < 5; -- commit; -- commit if data is correct
I dont know if the attachments in jira are configurable, but ours are located in groups of 10000, e.g. bugs BUG-10001 to BUG-20000 are in folder ./20000 and so forth.
This will only work, if the behavior is the same.
Usage:
define PROJECTKEY = 'BUG'; -- Project Key of the Bug-Project select shell_command from ( select '#!/bin/bash' shell_command, 1 rnk from dual union select 'if [ ! $(pwd | grep "data/attachments/&PROJECTKEY") ]; then echo "ERROR: You need to execute the script in the jira-attachments directory of Project &PROJECTKEY"; exit 1; fi' shell_command, 2 rnk from dual union select 'for f in $(find . -type d | grep "&PROJECTKEY-[0-9][0-9]*$"); do mv $f ${f}_moved; done' shell_command, 3 rnk from dual union select 'if [ ! -d "./'|| dir|| '" ]; then mkdir ./' || dir ||'; fi' shell_command, 4+(dir/1000000) rnk from ( select distinct ceil(bugzillaid/10000)*10000 dir from zilla_to_jira_tmp) union select 'if [ -d ./' || ceil(jiraissuenum/10000)*10000||'/'||OLDJIRAKEY || '_moved ]; then ' ||'mv ./'|| ceil(jiraissuenum/10000)*10000||'/'||OLDJIRAKEY || '_moved ./' || ceil(bugzillaid/10000)*10000||'/'||NEWJIRAKEY || '; fi' shell_command, 5+jiraissuenum rnk from FILEATTACHMENT fa join ZILLA_TO_JIRA_TMP bz on (fa.issueid = bz.issuepk) where oldjirakey != newjirakey ) order by rnk;
