Keyboard shortcut for Bulk Changes (reduce number of clicks)
Saad
February 6, 2019 edited
Hi
I am using Agile boards and I want to reduce the number of clicks needed to complete a bulk transition on multiple cards.
For example Transition multiple issues at once from Status 'X' to Status "Y". If I do a bulk change using right click, there are additional 4-5 clicks needed to fully complete the Bulk change (all the way to the acknowledge button) and my team are very unhappy with that. Would be great if you could reduce the number of clicks somehow for a simple transition for multiple cards
I tried using the keyboard shortcuts, when I select multiple tickets, I normally press "." then "i" . However that only does it for one Issue not the multiple selected.
My team needs to multi card transitions very frequently as our email flow is enormous.
Can that be developed?
Saad
Gurpreet
February 6, 2019
cant you select multiple issues on your Active sprint view of your board and then simpy drag and drop under a new column ?
Saad
Hi Gurpeet
is it possible to drag and drop multiple cards in one click?
Gurpreet
February 6, 2019
yes. you can select multiple cards on active sprint view of board using ctrl key and then jst drag them to another column.
Saad
ok so apparently that only works in JIRA cloud and not JIRA Server. How very frustrating!
https://jira.atlassian.com/browse/JSWSERVER-9581?_ga=2.120029952.908644644.1549312434-410625077.1543955820
Can we figure another way?
Like • Gurpreet likes this
Gurpreet
February 6, 2019
aah bugger.
from that issue looks like many ppl are disappointed that this feature not in jira server while it is present in jira cloud. pray that atlassian implements this.
yuqiuge
August 3, 2020
is there a short cut for dragging a issue to the next column ?
Learn more
