Don't ask why, but our internal LDAP is setup to support 3 common name (cn) values. My account, for example, uses chapmar, roy.chapman@ubs.com and 43414247. All 3 are valid logins and all authenticate against the same password.
We would like to standardise against the login id, chapmar in the above example. The manual page for LDAP https://confluence.atlassian.com/display/USERMAN/_LDAP+User+Schema+Settings suggests this setting
User Unique ID Attribute
The attribute used as a unique immutable identifier for user objects. This is used to track username changes and is optional. If this attribute is not set (or is set to an invalid value), user renames will not be detected — they will be interpreted as a user deletion then a new user addition.
This should normally point to a UUID value. Standards-compliant LDAP servers will implement this as 'entryUUID' according to RFC 4530. This setting exists because it is known under different names on some servers, e.g. 'objectGUID' in Microsoft Active Directory.
Would this help do you think? Could we setup LDAP so the user can login as any one of the 3 above but all would be treated as the login id? Do you have any example of the usage of this field?
Hey Roy,
Maybe you can experiment with the User Object Filter. The default filter is
(&(objectCategory=Person)(sAMAccountName=*))
But, you can also have AND and OR conditions in it. There are some examples here
http://www.google.com/support/enterprise/static/postini/docs/admin/en/dss_admin/prep_ldap.html
and
https://confluence.atlassian.com/display/DEV/How+to+Write+LDAP+Search+Filters
I have not experimented with this but something for you to look at
