LDAP quick connects but fails on AD search
Brad Pink
January 7, 2014
Attempting to connect to Microsoft Active Directory.
Initial (quick) test returns: "Connection test successful."
Search of AD returns:
"Test retrieve user : Failed
org.springframework.ldap.NameNotFoundException: [LDAP: error code 32 - 0000208D: NameErr: DSID-031001E5, problem 2001 (NO_OBJECT), data 0, best match of: '' ]; nested exception is javax.naming.NameNotFoundException: [LDAP: error code 32 - 0000208D: NameErr: DSID-031001E5, problem 2001 (NO_OBJECT), data 0, best match of: '' ]; remaining name '/'"
Config is as follows:
=== Current user ===
Directory ID: 1
Username: ########
Display name: #############
Email address: ########@#######.org.au
=== Directories configured ===
Directory ID: 10000
Name: Active Directory server
Active: true
Type: CONNECTOR
Created date: Wed Jan 08 15:19:47 CST 2014
Updated date: Wed Jan 08 15:33:34 CST 2014
Allowed operations: [CREATE_GROUP, DELETE_GROUP, UPDATE_GROUP, UPDATE_GROUP_ATTRIBUTE, UPDATE_USER_ATTRIBUTE]
Implementation class: com.atlassian.crowd.directory.MicrosoftActiveDirectory
Encryption type: sha
Attributes:
"autoAddGroups": "jira-users"
"com.atlassian.crowd.directory.sync.currentstartsynctime": "null"
"com.atlassian.crowd.directory.sync.issynchronising": "false"
"com.atlassian.crowd.directory.sync.lastdurationms": "63"
"com.atlassian.crowd.directory.sync.laststartsynctime": "1389157414304"
"crowd.sync.incremental.enabled": "true"
"directory.cache.synchronise.interval": "3600"
"ldap.basedn": "#######.local"
"ldap.connection.timeout": "10000"
"ldap.external.id": "objectGUID"
"ldap.group.description": "description"
"ldap.group.dn": "###### groups"
"ldap.group.filter": "(objectCategory=Group)"
"ldap.group.name": "cn"
"ldap.group.objectclass": "group"
"ldap.group.usernames": "member"
"ldap.local.groups": "true"
"ldap.nestedgroups.disabled": "true"
"ldap.pagedresults": "true"
"ldap.pagedresults.size": "1000"
"ldap.password": ********
"ldap.pool.initsize": "null"
"ldap.pool.maxsize": "null"
"ldap.pool.prefsize": "null"
"ldap.pool.timeout": "0"
"ldap.propogate.changes": "false"
"ldap.read.timeout": "120000"
"ldap.referral": "true"
"ldap.relaxed.dn.standardisation": "true"
"ldap.roles.disabled": "true"
"ldap.search.timelimit": "60000"
"ldap.secure": "false"
"ldap.url": "ldap://########:389"
"ldap.user.displayname": "displayName"
"ldap.user.dn": "###### users"
"ldap.user.email": "mail"
"ldap.user.encryption": "sha"
"ldap.user.filter": "(&(objectCategory=Person)(sAMAccountName=*))"
"ldap.user.firstname": "givenName"
"ldap.user.group": "memberOf"
"ldap.user.lastname": "sn"
"ldap.user.objectclass": "user"
"ldap.user.password": "unicodePwd"
"ldap.user.username": "sAMAccountName"
"ldap.user.username.rdn": "cn"
"ldap.userdn": "JIRA_USER@######.local"
"ldap.usermembership.use": "false"
"ldap.usermembership.use.for.groups": "false"
"localUserStatusEnabled": "false"
Directory ID: 1
Name: JIRA Internal Directory
Active: true
Type: INTERNAL
Created date: Thu Feb 28 11:57:51 CST 2013
Updated date: Thu Feb 28 11:57:51 CST 2013
Allowed operations: [CREATE_GROUP, CREATE_ROLE, CREATE_USER, DELETE_GROUP, DELETE_ROLE, DELETE_USER, UPDATE_GROUP, UPDATE_GROUP_ATTRIBUTE, UPDATE_ROLE, UPDATE_ROLE_ATTRIBUTE, UPDATE_USER, UPDATE_USER_ATTRIBUTE]
Implementation class: com.atlassian.crowd.directory.InternalDirectory
Encryption type: atlassian-security
Attributes:
"user_encryption_method": "atlassian-security"
BernardoA
January 27, 2014
Maybe some 'CN' does not exist or no longer exists when it periodically attempts to synchronize with the Directory.
Septa Cahyadiputra
January 7, 2014
Hi Brad,
It seems there is a misconfigureation on your end. According to your error, you are currently encountering a known issue which is describe in detail here:
https://confluence.atlassian.com/display/CONFKB/LDAP+Error+Code+32
Please refer the above KB and see if it helps.
Septa Cahyadiputra
Timo Riikonen December 21, 2016
Basically 32 says that your query results with zero lines.
Note that the query is assembled from three settings:Base DN, Additional User DN and User Object Filter.
In my case I tried to use conflicting settings on the last two as I had forgotten the third setting.
Register Now
