it is present this type of report in jIra on demand?In particular LInk Hierarchy report for issue
In the past version it's present
Hi Alberto,
I'm sorry to inform you that, as per our OnDemand plugin policy, it is not possible to install plugins into the OnDemand environment unless they have been bundled by our developers and as the Links Hierarchy Reports is supplied by a plugin this isn't available in the OnDemand environment. The reason plugins are not allowed in the OnDemand environment is because OnDemand is an integrated environment and untested plugins can cause serious stability and security issues so I hope you will understand that we cannot assist you with this request.
However, there are a number of other reports that you can generate in your OnDemand instance so I'd like to ask you to take a look at the following document which details the possibilities: https://confluence.atlassian.com/display/AOD/Generating+Reports
All the best,
John
