Label Manager custom field, add label from Task to Epic.
Labadie_ Agustin - Contractor
October 14, 2024
Hi community, I´m setting an automation to add a label in a label manager field in a parent issue from the same field in a child issue. I´m not looking for replacing the value/s. I looking to add them to the existing ones.
This field doesn´t appear on the Choose field to set dropdown, so I went with More Options. How I have it currently set works only if there is one or less label on each issue.
If there are already two Labels on the parent issue, or there are two labels on the triggerIssue this automation fails. Here are the Audit logs.
The labels are indeed defined as it is the same project, but instead of reading it as two labels it is reading it as one longer label.
Any idea? I think this can also be approach with scriptrunner but I wouldn´t know how to go about it.
