Labels Tab missing on JIRA Project Dashboard Page
Build Monkey
for our JIRA v 6.2.1 install, the Labels Tab is missing on the Project Dashboard. Going to this page:
https://confluence.atlassian.com/display/JIRA/Browsing+a+Project%27s+Summary
Explains we are missing a label plugin, but when I go to this page for the plugin:
https://marketplace.atlassian.com/archive/com.atlassian.jira.plugin.labels
It says the plugin has been archived.
How do we get that Labels Tab back?
Thanks.
Bruce Boutet February 13, 2015
I concur, labels have been used extensively in our instance. How can we re-enable this feature?
Nicolas_Grussenmeyer June 16, 2014
OK, I just found this : https://confluence.atlassian.com/display/JIRA/JIRA+6.2+Upgrade+Notes?utm_source=SAC&utm_medium=dashboard#JIRA6.2UpgradeNotes-LabelsandPopularIssuestabsremovedfromProjectOverview
The "Labels" tab removal seems to be a "feature" of the 6.2 update.
Atlassian, please provide the ability to enable this feature if needed
Same problem here on JIRA v6.2.2#6258-sha1:2012433
Any solution to this problem ? This is very annoying.
