Licence required for a Jira and Confluence sandbox?
SabrinaB November 18, 2013
we want to install a JIRA and a Confluence sandbox in our server but I was wondering if we need another licence for that?
Thanks for the help,
Sabrina
Nic Brough -Adaptavist-
November 18, 2013
You do require a licence for any installation of Jira or Confluence.
However, if you have commercial licences, you have "developer" licences available, which are expressly for creating development and test systems to help you support your production instances.
Go to your my.atlassian account and look at your licences - underneath each block of licence code, there should be a link to the developer licence for each application.
SabrinaB November 19, 2013
Thans very much Nic!
Erik Saline [BlackPearl PDM]
November 19, 2013
Check out the Atlassian SDK, you do not need licenses to use it and you can run most Atlassian products with just a single command.
https://developer.atlassian.com/display/DOCS/Set+up+the+Atlassian+Plugin+SDK+and+Build+a+Project
Register now
