Limit custom field options (dropdown list) on Screen
Oleksandr Presich
Hello guys,
please advise if it is possible to limit custom field options through the properties screen by analogy to the: jira.field.resolution.include?
We are using JIRA 6.2
Mizan
May 12, 2014
It is not possible by setting a workflow property however using behaviours plugin you can hide options of a specific customfield on a specific workflow transition . You will need write a groovy script which will hide the options then add a condition so that this script is executed only where you want it . You can refer a similar example here https://jamieechlin.atlassian.net/wiki/display/JBHV/Miscellaneous+Behaviours+Examples#MiscellaneousBehavioursExamples-Addorremoveoptionstosingleormulti-selectfields
Tiago Comasseto
May 11, 2014
Hi, we currently hava an improvement request opened to add the ability of limiting the visibility of custom fields values in this link. You may post your comments there and add yourseld as watcher for futher updates.
Cheers
Oleksandr Presich
I don't need to limit visibiliy of the issue. What I want is only to include only 2 from 3 options in Dropdown list.
Deleted user May 11, 2014
Hi Oleksandr,
Using the jira.field.resolution.include is not yet possible and you have to use jira.field.resolution.include to do the job.
There is still an open ticket to also include the jira.field.resolution.include property:
https://jira.atlassian.com/browse/JRA-16443
