×Hi all,
I'm wondering if there's a way to set the users for an add-on or the project that can use it since it's just need it for a certain project and I want to control that only people from this project can use the add-on.
Hi @PaulaA,
From JIRA itself, you can not restrict certain users from using the add-on. But also it depends on the type of add-on you use and what areas of JIRA it covers, so, possibly tweaking JIRA's configuration can also restrict add-on usage.
However, add-on vendor can do that for you. Actually, add-on developer can modify accessibility of add-on based on permissions given to users or projects. Unfortunately, most add-ons does not provide such feature.
I hope this helps.
Thanks.
No, licensing won't work that way, you need to pay for number of users your instance have and not the only users who will be using that add-on. I think it would be much better if we pay only for those users who actually use add-on. But for now that's not the case. :)
