×hi all,
is there any way to force JIRA not to accept sub-task due dates that go beyond the parent's issue due date?
Eg:
From my reasoning this should be a condition during the issue creation process...
Any suggestions?
thanks,
Jacques.
You'll need to find or write a "validator" to do this (a "condition" will stop a transition from being offered to a user - that's a bit too early in the lifecycle)
thanks Nic,
where would I look for such a validator? I (still have no) experience with programming in/for JIRA.
thx,
Jacques.
https://plugins.atlassian.com/ is the place to start.
Thanks Nic! On my way there now!
It absolutley depends on your process.
But I'd say that in the majority of cases, no - you would not want a parent issue to have it's due date amended by a sub-task - if that happens, your main task would have been changed, probably without any oversight by a human. Jacques approach feels more correct - if a human needs to push a sub-task out past the main task's due-date, then it's very likely that a batch of humans need to know, and discuss the problem. As someone who has to deliver stuff to deadlines, I absolutely would NOT want my deadlines being changed just because we're breaking up work into bits.
Was wondering, it should be rather the other way, the parent task due date should get shifted as per the latest due date from the sub-tasks. Isn't it?
