Limit sub-tasks
kdickason
I have ScriptRunner with Jira Data Center.   Has anyone figured out a script that can limit which sub-tasks my user can choose from based on what Issue Type they have created. Not all my sub-tasks are appropriate for all the issue types on my project. Atlassian indicates they do not support this, so I was hoping I could script something.  I'm terrible with scripting so I really need something with detailed instructions if you can help me.  I have 3 issue types (A, B, C)) and I have 3 sub-task types. (a, b, c).  I want to limit each Issue Type so a user can only pick the same sub-task type (Issue Type A allows creation of only sub-task a, Issue Type B allows creation of only sub-task b, Issue Type C allows creation of only sub-task c.)  Help??
Radek Dostál
August 18, 2022
That's something that needs to be done by behaviours as Jira otherwise doesn't support this in any way (other than workflow errors).
Working with these 2 as inspiration:
 # https://scriptrunner.adaptavist.com/6.20.0/jira/recipes/behaviours/restricting-issue-types.html
 # https://docs.adaptavist.com/sr4js/6.25.0/features/behaviours/behaviours-examples/sub-task-default-field
I tested the following which seems to work:
import com.atlassian.jira.config.IssueTypeManager
import com.atlassian.jira.issue.IssueManager
import com.atlassian.jira.issue.issuetype.IssueType
import com.onresolve.jira.groovy.user.FormField
import static com.atlassian.jira.issue.IssueFieldConstants.ISSUE_TYPE
import groovy.transform.BaseScript
import com.onresolve.jira.groovy.user.FieldBehaviours
@BaseScript FieldBehaviours fieldBehaviours
Long parentIssueId = null
FormField parentIssueIdField = getFieldById("parentIssueId")
if (parentIssueIdField != null && parentIssueIdField.getFormValue() != null)
parentIssueId = Long.valueOf(parentIssueIdField.getFormValue().toString())
if (parentIssueId == null || underlyingIssue != null) {
//Either, this is a not a sub-task; or, it already exists - do nothing
return
IssueManager issueManager = ComponentAccessor.getIssueManager()
String parentIssueTypeName = issueManager.getIssueObject(parentIssueId).getIssueType().getName()
IssueTypeManager issueTypeManager = ComponentAccessor.getComponent(IssueTypeManager)
Collection<IssueType> allIssueTypes = issueTypeManager.getIssueTypes()
List<IssueType> allowedIssueTypes = new LinkedList<>()
switch (parentIssueTypeName) {
case "Task":
allowedIssueTypes.add(allIssueTypes.find {
it.getName() == "Task Sub-task"
break
case "Story":
it.getName() == "Story Sub-task"
break
case "Feature":
it.getName() == "Feature Sub-task"
break;
default:
//do nothing, underlying parent issue is not listed
return
FormField issueTypeField = getFieldById(ISSUE_TYPE)
issueTypeField.setFieldOptions(allowedIssueTypes)
Test set up was just a custom Behaviour, mapping to the project (all issue types), and above is an initializer.
Needless to say, I recommend not going down this route, because maintaining all of the different groovy scripts can be a nightmare, and they are very difficult to find when they start misbehaving.
