Link an Issue to multiple epics
Dan Osborn
Is it possible to link an issue to multiple epics?
3 votes
Marcela Junyent
October 30, 2019
Not with epic link, but you could use a linked issue.
Or you could use components... depends on why you have the story in more than one epic.
I hope it helps..
Regards. Marce
Nick Huang
May 25, 2023
You are genius!!!! saved my life!!
Fabrice BERTAINA
February 21, 2022
Hello, there is a real need around this notion  the same improvement that needs to appear in different stories, just because we are working on different stories in parallel and they share some basic functions
Relates to  is not enough, because you can't see the evolution in a good way. Epic provides such a view.
Darren
The visibility on the progress through an epic, or 'how much longer will this take?' is brought about by breaking that Epic down into smaller bite-sized chunks so the Epic is slowly eaten, one bite at a time and we can measure that progress.
So in that sense, Epic 1 has a set of Work Items (issues) that are its 'bites', and Epic 2 has a different set.
and the reporting relies on that.
But I get that there may be a sense of 'Hey, I just realised that this work also contributes to that 2nd Epic over there.'
All I can think of is:
  • a 2nd issue for the 2nd Epic that contains nothing more than says 'please see issue 1 over there (issue links)
  • and Automation updates both issues as they progress through the workflow.
could that work?
David Noland
August 1, 2022
We have a use case where we have tasks come in related to one epic but are effectively an interrupt, so we use a second epic to identify interrupt issues.  Would there be a more effective way to identify interrupts and report on these without having to duplicate tasks?
Sean Foxhall
January 31, 2023
I have run labels on issues that are interrupts (such as "Sprint-22-OutsideWork"), keeping these issues outside of the running sprint. I then run a filter on a dashboard to roll up all of these interrupt issues during reviews. It helps preserve the sprint from massive scope change but also provides visibility to the org that the team is getting pulled off the sprint goal.
Like • Darren likes this
Sheila Perez
January 17, 2022
Is there any plugin in the marketplace that would allow us to do this?
Avinash Bhagawati {Appfire}
Hi @Dan Osborn ,
Currently you cannot link issue to multiple epics via Epic Link due scrum board constrains as it may deviate your report results.
As alternative you can link issue with more epics with issue linking feature in Jira. Also if you can create duplicate issues and link them to individual epics if you looking to get more accurate reports for your epics.
Avinash
