Link multiple created field to custom field
RedPS
January 22, 2020 edited
Hi.. recently i figured out that it's possible to add form field from Description value..
hence I use this "feature" to create a dynamic table whereby user can add row to the table.
From my understanding, it's only possible to link one input/form to one custom field.
but.. I would like to link together all the rows to one string template
for example
col 1 - name, col 2 - age, col 3 - dob.
row 1 - jane, 21, 01/03/1999
row 2 - joey, 24, 01/04/1997
this will be compiled as template below
Customer List
1 - Jane, 21 years old, 01/03/1999
2 - Joey, 24 years old, 01/04/1999
to one text-field multiline custom field
> example below
HTML CODE BELOW
<link href="//maxcdn.bootstrapcdn.com/bootstrap/3.3.0/css/bootstrap.min.css" rel="stylesheet" id="bootstrap-css">
<script src="//maxcdn.bootstrapcdn.com/bootstrap/3.3.0/js/bootstrap.min.js"></script>
<script src="//code.jquery.com/jquery-1.11.1.min.js"></script>
<!------ Include the above in your HEAD tag ---------->
<script>
window.onload = ()=>{
if(document.getElementsByClassName("hideifOnSetting")[0].parentElement.getAttribute("class") == "description")
{ document.getElementsByClassName("hideifOnSetting")[0].style.display = "none" }
else
{ document.getElementsByClassName("hideifOnSetting")[0].style.display = "block" }
</script>
<div class="hideifOnSetting">
<table id="myTable" class=" table order-list">
<thead>
<tr>
<td>Activity</td>
<td>Responsible Person</td>
<td>Start Time</td>
<td>End Time</td>
<td>Status (Pass/Fail)</td>
</tr>
</thead>
<tbody>
<tr>
<td class="col-sm-4">
<input type="text" name="activity" class="form-control" />
</td>
<td class="col-sm-2">
<input type="mail" name="rperson" class="form-control"/>
</td>
<input type="text" name="starttime" class="form-control"/>
</td>
<input type="text" name="endtime" class="form-control"/>
</td>
<input type="text" name="status" class="form-control"/>
</td>
<td class="col-sm-6"><a class="deleteRow"></a>
</td>
</tr>
</tbody>
<tfoot>
<tr>
<td colspan="5" style="text-align: left;">
<input type="button" class="btn btn-lg btn-block " id="addrow" value="Add Row" />
</td>
</tr>
<tr>
</tr>
</tfoot>
</table>
</div>
JS CODE BELOW ->
$(document).ready(function () {
var counter = 0;
$("#addrow").on("click", function () {
var newRow = $("<tr>");
var cols = "";
cols += '<td><input type="text" class="form-control" name="activity' + counter + '"/></td>';
cols += '<td><input type="text" class="form-control" name="rperson' + counter + '"/></td>';
cols += '<td><input type="text" class="form-control" name="starttime' + counter + '"/></td>';
cols += '<td><input type="text" class="form-control" name="endtime' + counter + '"/></td>';
cols += '<td><input type="text" class="form-control" name="status' + counter + '"/></td>';
cols += '<td><input type="button" class="ibtnDel btn btn-md btn-danger " value="Delete"></td>';
newRow.append(cols);
$("table.order-list").append(newRow);
counter++;
$("table.order-list").on("click", ".ibtnDel", function (event) {
$(this).closest("tr").remove();
counter -= 1
function calculateRow(row) {
var price = +row.find('input[name^="price"]').val();
function calculateGrandTotal() {
var grandTotal = 0;
$("table.order-list").find('input[name^="price"]').each(function () {
grandTotal += +$(this).val();
$("#grandtotal").text(grandTotal.toFixed(2));
Julie d_Antin _Elements_
Hi  @RedPS ,
This isn't a solution linked to a custom field, but one of the app Elements Checklist my company makes provides a solution that looks like just what you are trying to achieve.
You can create multiple columns with lots of different attribute types, including a user picker for things like "Responsible person" in your example, select lists, calculated attributes, and more.
It would work as a dynamic table for users, like you are looking for, since users can add lines to the checklist and any footers or calculations are automatically updated.
You can try it for free to see if meets your needs:
https://marketplace.atlassian.com/apps/1217646/
Laura
RedPS
ive tested this just now, but i seem to only be able to create the checklist after creating a ticket though.. there seems to be no guidance to create checklist in the create ticket form
RedPS
January 23, 2020 edited
(free method)
Hi.. just an update, what i did was using multi line text editor and set the renderer to wiki style, then create a template then copy and paste (text value) as default value..
however you wont be able to insert user field and other custom field and only text field though... and can't search by using jql
