i want to create a Link for a Dashboard where the user clicks the Link and gets to a screen where he can create an Issue for my specific Project. When you use the normal Jira link (https://jira.com/secure/CreateIssue!default.jspa) it opens the Screen i want but with the Project and Issue preselected that was last used by the User. When i use this Link i made with the project Id and Issuetype ID preset it tries to create the Issue by clickingthe Link and that shows a fail because all the required fields are not filled in. (https://jira.com//secure/CreateIssue!default.jspa.jspa?pid=15300&issuetype=14101)How can i get a link where i can preset Project and Issuetype but jira doesnt try to create the Issue on click?
Hi @GS1337 ,
Your posted links is incorrect. Example for my instance:
http://localhost:8087/secure/CreateIssue.jspa?pid=10000&issuetype=10002
B.R.
Please vote for https://jira.atlassian.com/browse/JRASERVER-23590 for a full featured version where all fields can be assigned with default values this way.
Found URL to select Project and Issue type and create a ticket :)
https://[jiraurl]/secure/CreateIssue!default.jspa
or
https://[jiraurl]/secure/CreateIssue.jspa?pid=10002&issuetype=10009 - no errors
Bad URL:
https://[jiraurl]/secure/CreateIssueDetails!init.jspa?pid=10002&issuetype=10009 - errors about mandatory fields
Hey @GS1337 - I would apply the json below
pid = project id
issue type = issue type id
assignee = if you want to assign a assignee - their user name
set priority = priority id
*** any other required field on the create screen.
Hi @GS1337 ,
Maybe I misunderstand, but issue won't create by link until user click 'create' button.
Could You please clarify, what mean 'issue mask'?
B.R.
He has the same problem as I do.
We need a URL to open a page to create a ticket.
The problem is that when you enter that URL
...secure/CreateIssueDetails!init.jspa?pid=10002&issuetype=10009
you immediately see errors on the screen about mandatory fields.
Those errors should be visible after a user will click "Create" button not when he opens the page.
and when I enter this URL
I got error that "issuetype: No issue type selected."
I saw in some post that Atlassian team member posted some comment with correct link to create a feature request in Atlassian Jira but I can't find it.
It was a page with a preselected project and with the ability to select issue type and click Next button to enter a page with all fields.
Andrew / Sam:
Can you pass the value of the required fields in the json? Also is a Tempo Account Field Required? Using json we were unable to get past that. Going thru the api we could just pass the account value
Does this also work in combination with a predefined template?
We have too much templates on our jira server, performance is a mess and selecting one requires a lot of waiting time so I would like to generate a few direct links in order to being able to create issues directly from a certain template.
