LinkageError when using jira-api and jira-core together
barbosa_s_alexandre July 25, 2017
Hi guys.
I'm preparing some old plugin, developed in Jira 3.X, to upgrade to Jira 7. In particular, I'm creating a new plugin with single-issue-view to generate an customized word document. Meanwhile, the old plugin use some jira-core classes, like AbstractIssueHtmlView and JiraVelocityUtils.
When I added the jira-core, everything compile well and using atlas-mvn package, I was able to test the plugin with successfull. In the other hand, when I restart the server (Ctrl+C and atlas-run), I'm getting the following error.
___ FAILED PLUGIN REPORT _____________________
1 plugin failed to load during JIRA startup.
'com.mycompany.issueoperations' - 'issueoperations' failed to load.
Unexpected exception parsing XML document from URL [bundle://167.0:0/META-INF/spring/plugin-context.xml]; nested exception is java.lang.LinkageError: loader constraint violation: loader (instance of org/apache/felix/framework/BundleWiringImpl$BundleClassLoaderJava5) previously initiated loading for a different type with name "org/w3c/dom/Element"
It was loaded from C:\projects\TTT\source\issueoperations\target\jira\home\plugins\installed-plugins\issueoperations-1.0.jar
Anyone knows how can I avoid this error?
Thanks.
Hartmut Klein
September 6, 2017
I'm encountering the same problem. To avoid the org.w3c.dom.Element LinkageError I exclude the xml-apis from my dependency.
However now I get the NoClassDefFoundError and ClassNotFoundException for org.w3c.dom.Element.
I already inserted all packages in <Import-Package>
and even tried to add the xml-apis as a dependency in the pom.xml.
Do you found a solution to fix this?
barbosa_s_alexandre September 6, 2017
Exclude xml-apis solved my problem. I'm running the blank plugin above, using the commands provided by atlassian sdk (atlas-run), version 6.2.14.
The version of Java is 1.8. Note that, Java 8, has the class org.w3c.dom.Element in the rt.jar
barbosa_s_alexandre July 26, 2017
Hi Matt.
I created a new plugin (blank plugin) and added jira-core in pom.xml
<dependencies>
<dependency>
<groupId>com.atlassian.jira</groupId>
<artifactId>jira-api</artifactId>
<version>${jira.version}</version>
<scope>provided</scope>
</dependency>
<!-- Add dependency on jira-core if you want access to JIRA implementation classes as well as the sanctioned API. -->
<!-- This is not normally recommended, but may be required eg when migrating a plugin originally developed against JIRA 4.x -->
<dependency>
<artifactId>jira-core</artifactId>
</dependency>
The error happened in the same way, as you can see...
2 plugins failed to load during JIRA startup.
'com.bcompany.trk.blank' - 'blank' failed to load.
It was loaded from C:\projects\TRK\source\blank\target\jira\home\plugins\installed-plugins\blank-1.0.jar
'com.bcompany.trk.blank-tests' - 'blank' failed to load.
Application context initialization for 'com.bcompany.trk.blank-tests' has timed out waiting for (objectClass=com.bcompany.trk.blank.api.MyPluginComponent)
It has the following missing service dependencies :
&myComponent of type (objectClass=com.bcompany.trk.blank.api.MyPluginComponent)
It was loaded from C:\projects\TRK\source\blank\target\jira\home\plugins\installed-plugins\blank-1.0-tests.jar
Looking for errors like this, I found a way to solve the problem. I'm not sure if it is the better solution, but worked. In the jira-core dependecy, I add an exclusion to xml-apis
<dependency>
<!-- exclude xml-apis - LinkageError on startup: org.w3c.dom.Element -->
<exclusions>
<exclusion>
<groupId>xml-apis</groupId>
<artifactId>xml-apis</artifactId>
</exclusion>
</exclusions>
</dependency>
Anyone else has a different solution for this problem? It's documented anywhere?
MattS
July 25, 2017
Looks like something in the atlassian-plugin.xml file? Try creating a brand new plugin and see if that compiles and runs
Help us plant more trees
