Linked Issues in the Issue Navigator
Mike Curwen NL
Wanted to tweak the output of "Linked Issues" in the Issue Navigator. Wanted to know if anyone knows how to, or has ideas on how to:
1) Show only certain types of links.
2) pull in the issue summary, for the linked issue (rather than just showing the issue key, it shows the summary)
Pablo Beltran
January 29, 2014
Not sure, but the Links Hierarchy add-on might help.
It displays the summary and allows users to filter by link type. The links are drawn in a tab...
Mike Curwen NL
Thanks, I did see that. Must be in the issue navigator though, as the business case is actually to then Export to Excel - and the Excel must contain the summary.
Pablo Beltran
January 29, 2014
It supports export to Excel. The linked issues are exported by preserving the hierarchy and in a flat table too. Furtheremore you can export it to SQL (JIRA issue search view) and export from there to other formats supported by JIRA.
