Linked issues problem on issue creation
Conor McGmail January 7, 2014
On our JIRA instance we are encountering the problem where the "Linked Issues" are failing to save when entered on issue creation.
We are running JIRA 6.0.5
When i create an issue and enter an issue link, Jira locates the linked issue and saves without any error. However upon completion of the save, the Linked Issues field is blank. Bizarrely if I open the issues history tab it has recorded that I have indeed linked the issue although the field itself is blank.
This is causing us serious pain as we are trying to use "Linked Issues" to populate a Structure for a hierarchical display of our project.
What i have had to do is remove Linked Issues from the Create Screen and ask that our users create the issue and save it. Then edit the issue and provide the links. This is cumbersome and time consuming.
Can someone please help with this one? Thanks
Igor Sereda [ALM Works]
January 7, 2014
Hi Conor, which version of Structure are you running? Could you please post a screenshot of your Links synchronizer settings (open Manage Structures, locate the structure and click Settings in the Sync With... column).
Help us plant more trees
