Linking issues if custom field value is same
faizulc September 21, 2018
Hi-
Need some help with the use case below. Thank you in advance for your inputs!
Have these plugins:
a)ScriptRunner
b)JIRA Misc Workflow Extensions
c)JIRA Suite Utilities
d)JIRA Workflow Toolbox
e)Workflow Enhancer for JIRA
Project “ESC” has a custom field “Customer Name”(id=11790). Project “CCE” shares that custom field. If an issue in project “ESC” has a custom field value that is the same as other issues in Project “CCE”, the issues from Project “CCE” needs to be linked to that issue in “ESC”.
Deleted user October 3, 2018
Hi @faizulc,
You can use JIRA Misc Workflow Extensions addon for linking the issue. based on the conditions you can achieve it. Here is the article for the same https://innovalog.atlassian.net/wiki/spaces/JMWE/pages/139896998/Link+issues+to+the+current+issue
Sravya
