Linking to external Site
Martin Heinz October 5, 2017
Hi!
We are currently trying to solve a problem:
We use SharePoint to store our documents. These documents have the Issue Key as metadata so I would be able to generate a link that filters on the documents related to each issue.
We would like to generate this link for each issue created and I was hoping that this was possible using a transition - but even if I dont use the external link and maybe try to update a url field, I dont find any documentation on a variable for the issue key that I could append on the field I try to update.
Is there any way to solve this?
Lime Trees
We have plugin Link FInder which could resolve your problem. It is our new plugin and we would be very gratefull for your feedback.
If you have any questions please let us know.
Nic Brough -Adaptavist-
October 7, 2017
Could you explain how it solves the problem?
Martin Heinz October 8, 2017
Yes, that would be great. What does your plugin have to do with our problem?
Lime Trees
Hi Maritn and Nic
I'm sorry for long answer. Actual in this case our plugin is not able to help you. I'm sorry again for spam. I did not read your question carefully.
BR.
