List all the issues of a project with JIRA Python
Antoine
October 3, 2016
Hello all,
All the question is in the title, how to list ALL the issues of a project with JIRA python ?
Actually i've done this code :
def simple_issue(projects):
    i = jira.search_issues('issuetype=Bug', maxResults=None)
    print(i)
But it list only 50 issues or less. It is due to the fact that issues during the search are shown by pages containing each 50 issues and the python package cannot access to the next pages. Do you know how could i do ?
Or then not to reach has the list of issues but to reach has the list of issuetypes present in the config of the project?
10 votes
MattS
October 3, 2016
block_size = 100
    block_num = 0
    while True:
        start_idx = block_num*block_size
        issues = jira.search_issues(jql, start_idx, block_size)
        if len(issues) == 0:
            # Retrieve issues until there are no more to come
            break
        block_num += 1
        for issue in issues:
            log.info('%s: %s' % (issue.key, issue.fields.summary))
Antoine
October 3, 2016
it works, thank you !
Like Kawaljeet Singh likes this
Behnam Kasmapour Seighalani
September 21, 2017 edited
Hi all,
I tried this code and got an error for name 'jql'
[SOLVED]
Then later on when I'm done with this error I get a new one for 'log'
 [SOLVED]
Alwyn
January 18, 2019
Solved how?
Like 2 people like this
Aamir Jamil
March 3, 2020
#NOW SOLVED THANKS :)
while True:
start_idx = block_num * block_size
if block_num == 0:
else:
more_issue = jira.search_issues(jql, start_idx, block_size)
if len(more_issue)>0:
for x in more_issue:
issues.append(x)
else:
break
break
block_num += 1
print(len(issues))
print('hi %s: %s' % (issue.key, issue.fields.summary))
Matt Ashfield October 3, 2016
see args of the function...
search_issues(jql_str, startAt=0, maxResults=50, validate_query=True, fields=None, expand=None, json_result=None)
use startAt and maxResults looping round incrementing StartAt by maxResults
wink
Antoine
October 3, 2016
    i = jira.search_issues("project=project_name", startAt=0, maxResults=50, validate_query=True, fields=None, expand=None, json_result=None)
print(i)
It list 50 issues too ...
Jeff
October 3, 2016
That is because you are still specifying maxResults=50, try changing to maxResults=2000
Marcello Romani
October 20, 2017
The server won't return more than a configured number of results at most.
I believe the default is 1000.
Modha K Khammammettu January 26, 2018
Can you please post full python script. I am having issues getting connection 405 error.
Nic Brough -Adaptavist-
January 26, 2018
405 has nothing to do with your script, it happens when you are attempting to pass back a file that does not have the necessary permissions on the server to receive Post information from another script.
In other words, your script is asking Jira to do something it does not have permissions to do.  Check what you are asking is correct and the user has the correct permissions
Modha K Khammammettu January 26, 2018 edited
Hello Nic
Thanks for response
Here is the script: (I am using Jira 7.4.4 )
import httplib
import urllib
import json
conn = httplib.HTTPConnection("myjira:2002")
args = urllib.urlencode({'username':'myuser', 'password':'mypassword'})
headers = {'accept':'application/json'}
r1 = conn.request("post","/rest/auth/1/session",args, headers)
# --- Authenticate to jira ----------------
r2 = conn.getresponse()
print r1,r2.status,r2.reason,r2
Not sure what is wrong?
January 26, 2018
Nor do I.  405 means you don't have permission to post.  Are you sure you have the right url, the right user details and that the call you are making is supposed to be a post?  And are you sure python sends it over in the right format?
I am admin on Jira and using same credentials. Is there anyway to find out more info for  debugging.
Url is fine as I use same url for logging from browser.
The call I am making is a post as you can see in code
tested using postman and I get 415 error: Unsupported Meda type
used application/json (lower case A as well)
Logs atlassian-jira-security.log shows this:
http-nio-2002-exec-829 myuser 826x10767233x1 86f8ya 1yy.1xx.2xx.xxx /rest/auth/1/session The user 'myuser' has PASSED authentication.
Eric Sebian
Good morning. Looking at the response:
print(i)
is there a wildcard that I can use for project? Of course I tried "*" but that didn't work. I haven't been able to figure that out. Thanks.
Petar Petrov (Appfire)
October 3, 2016
Have you tried using maxResults=sys.maxint (or sys.maxsize if using Python 3)?
Antoine
October 3, 2016
import sys ?
blueinc May 16, 2022 edited
Here's another solution to this old question: I found, in the args of the function, this:
If maxResults evaluates as False, it will try to get all issues in batches.
So, if you just set maxResults=False, it will automagically return all the results. You don't have to guess at a number you 'think' might be higher than the actual number of results or do all of the batching manually.
issues = jira.search_issues(jql_str, maxResults=False)
HTH,
Brian
Vivian Young
July 15, 2020 edited
This is a really old question but I was wondering the same thing. My solution is slightly different from the ones mentioned above.
To remove the default limit of 50 issues, set the limit to something like this:
jira.jql(jql, limit=1000)
Hope this was helpful.
Shiva Prasad Rudrappa Hattaraki November 21, 2019
import jira.client
from jira.client import JIRA
jira_options={'server': 'https://jira.com'}
jira=JIRA(options=jira_options,basic_auth=('admin','password'))
issues_in_project = jira.search_issues('JQL',startAt=0, maxResults=2000, validate_query=True, fields=None, expand=None, json_result=None)
print (issues_in_project)
This will work for you.
Rushabh Patel
April 26, 2020
Hi Shiva,
Using your code it is giving just 100, where my expected answer is 455.
Prod Support
May 18, 2021
You can set the startAt index to be something else lets say 200 and maxResults to be 300 and it will give issues within that frame. This way you can find others as well and concatenate them. At a time, it gives max 100 issues only.
Register now
