I have a custom listener that works fine, but when I restart Jira, this listener does not work until I reinstall my custom addon.
This is the Listener:
public class CodProyectoListener implements InitializingBean, DisposableBean {
private static final Logger log = LoggerFactory.getLogger(CodProyectoListener.class);
private EventPublisher eventPublisher;
private ApplicationProperties applicationProperties;
private CodProyectoUtils codProyectoUtils;
public CodProyectoListener(ApplicationProperties applicationProperties, EventPublisher eventPublisher, CodProyectoUtils codProyectoUtils) {
this.applicationProperties = applicationProperties;
this.eventPublisher = eventPublisher;
this.codProyectoUtils = codProyectoUtils;
@Override
public void destroy() throws Exception {
eventPublisher.unregister(this);
@Override
public void afterPropertiesSet() throws Exception {
eventPublisher.register(this);
And this is the atlassian-plugin.xml:
<component-import key="eventPublisher" interface="com.atlassian.event.api.EventPublisher"/>
<component key="eventListener" class="es.mutua.jira.addons.listener.CodProyectoListener">
<description>Recupera informacion sobre el CF Código Proyecto.</description>
</component>
Can someone help me?
It is possible that the EventPublisher is not injected properly due to Atlassian Spring Scanner version. You might want to use the latest method of using annotations.
Check https://developer.atlassian.com/server/jira/platform/writing-jira-event-listeners-with-the-atlassian-event-library/ for sample code.
Also see https://bitbucket.org/atlassian/atlassian-spring-scanner/overview
