Listener that checks Checkbox when Custom field is edited.
GS1337
like the title suggests, i need a listener that checks a Checkbox if certain custom fields have been edited. Anybody knows something similar that i can use or has some suggestions?
Thank you in advance
Antoine Berry
September 5, 2019 edited
Hi @GS1337 ,
You can add this script in a Issue Updated listener :
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.issue.ModifiedValue
def customFieldChanged = event?.getChangeLog()?.getRelated("ChildChangeItem")?.find {it.field == "Name of your custom field"}
if (customFieldChanged){
def optionsManager = ComponentAccessor.optionsManager
int checkBoxFieldId = 13000
def checkBoxField = ComponentAccessor.getCustomFieldManager().getCustomFieldObject(checkBoxFieldId)
def checkboxFieldConfig = checkBoxField.getRelevantConfig(issue)
def options = optionsManager.getOptions(checkboxFieldConfig)
def optionsToSet = options.findAll { it.value in ["option1_to_check", "option2_to_check"] }
def checkBoxFieldValue = issue.getCustomFieldValue(checkBoxField)
checkBoxField.updateValue(null, issue, new ModifiedValue(checkBoxFieldValue, optionsToSet), new DefaultIssueChangeHolder())
Antoine
GS1337
Thx for your answer, i tried it but it shows an error in last line, when i try to execute it it gives me this error
The following log information was produced by this execution. Use statements like:log.info("...") to record logging information.
2019-09-06 09:44:51,907 ERROR [runner.AbstractScriptListener]: *************************************************************************************
2019-09-06 09:44:51,908 ERROR [runner.AbstractScriptListener]: Script function failed on event: com.atlassian.jira.event.issue.IssueEvent, file: <inline script>
org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed:
Script383.groovy: 17: expecting '}', found '' @ line 17, column 125.
1 error
GS1337
ok i found the mistake, its just a } at the end, but it still doesnt check my Box. I replaced
with my custom field name that should be checked for changes
I replaced this ID with the ID of my checkbox field
And i replaced this with the option of my Custom Field that should be checked like this
it.value in ["My_Option"]
What am i doing wrong?
Antoine Berry
You should check the logs to see if the code fails, and if it correctly enters the if condition when you edit the field.
Antoine Berry
Hi @GS1337 ,
Were you able to make this work ?
jira guy
September 4, 2019 edited
I see you are trying to use scriptrunner to achieve this. But I think automation for JIRA might be your best bet and is easy to configure. Both plugins offer customfield changed event in their listeners but Automation for JIRA offers the ability to capture specific field easily. You can then update the checkbox field as you see fit using the rule.
