Loading Jira FishEye Plugin API classes inside our custom plugin classes
Karanam Subbarao
I want to load Jira FishEye Plugin classes inside my PLugin. What is the best way to load the classes and execute the methods on the FishEye Plugin
Jobin Kuruvilla [Adaptavist]
January 8, 2013
The fisheye plugin exposes some of its functionality via components.You can use them if that gets you what you want. You can just add the plugin dependency and import those components to your plugin.
Help us plant more trees
