Log Work with Tempo plugin
Christos Moysiadis
February 5, 2019
Hello everyone,
quick info: When someone log work , puts the time in "From" & "To" fields, by default the plugin auto completes the Worked & the Billable fields.
In my case i want to have something like in the picture. The issue is a bug-task, and i want to log only the time that i work... so by default the plugin should not auto complete the Billable field.
  1. Is that possible?
  2. Or this is an global plugin fuction?
Best regards
CM
Deleted user February 5, 2019
Hi @Christos Moysiadis,
It is possible to turn off the billable hours field, see the documentation. You will need to be a Tempo Administrator or seek out your Tempo Admin to implement this change.
Hope this helps
Christos Moysiadis
February 5, 2019
Hello @[deleted],
and thank you for your quick reply .
So , as i see this configuration is global!
And this means , if i understand right , that if i disable this config then it will not be available for all the projects and issue type!
There is no seperation , in projects and issue types right?!
Best regards
Deleted user February 6, 2019
As far as I am aware that is correct.
If you would like to submit a change request to the product you can via Tempo's Jira Service Desk.
Christos Moysiadis
February 6, 2019
Hi @[deleted],
Thank you again for your time and knowledge!
Best regards
CM
