Log approvers to create/send notifcation event
Paul Roorda July 29, 2012
In the worflow, we have the 'field' Approved.
Issues need to be approved by an assignee, before they can be assigned to someone who starts the work on that isse.
I have a modified notification + worflow scheme that does not send an email on every update of the issue, just on a few updates like: Approved, Assignee Changed, Resolved.
Looking at the History of a Ticket, you'll see:
"Name" made changes - "date/time"
Status Open [ 1 ] Approved [ 10001]
when the issue has been approved (where Name is the approver).
(So I'm guessing) that Jira "logs" this info)
I'm trying to use these names/users (we have 2 approval fields in the workflow), so I can run an event on the listener in the workflow, to have Jira mail these Approvers that a ticket has been closed.
Of cos, I liek to have this done, where no user intervention is needed.
Anyone a suggestion on how I can accomplish this?
Jobin Kuruvilla [Adaptavist]
July 29, 2012
July 29, 2012
Those names are stored in custom fields I guess? If so, just read then using issue.getCustomFieldValue and then use it.
I know how to add the listener + event to put it in the workflow, so when a step in the isse is reached, the email will be send.
Whatt I'm after, is: How do I get those names of those approvers, so I can use this there?
Learn more
