Looking for Add-On or Solution for assignee's workload
Karrie Dash
October 12, 2017 edited
Here is the live-scenario:
Developer, Tom, is working on 3 projects that are staggered.
During each sprint planning, tasks are assigned to Tom. Each task has a story point associated with it.
I want a way to see how many story points are assigned to each developer per active sprint.
Example:
Project A: 10 Story Points
Project B: 12 Story Points
Project C: 6 Story Points
If there is a way to have a calendar view for each assignee, that would be even better.
Example:
On Tom's calendar, I can see that from Monday-Wednesday he has a total of 10 story points for Project A. Then, on Wednesday-Tuesday he has a total of 12 story points for Project B. Finally, on Monday-Friday he has 6 story points for Project C.
EDIT TO ADD:
I located an addon called "SumUP", which is shows the total number of points in an active sprint as a 2 dimensional table.
Aron Gombas _Midori_
This sounds like a candidate for an Excel pivot table with:
  • Dimensions:
    • Assignee
    • Project
  • Metric: SUM(story_points)
If so, then the Better Excel can generate this for you.
Check out the jira-agile-report.xlsx template, as you can customize that to solve your case. See these agile report examples
jira-agile-report-assignee-pivot-chart
Let's build A Rovo Agent 🤖
Save your spot
