Hello Team,
I want to create automatic daily or weekly tickets in Jira service desk or Jira, I believe Atlassian do not ship with this feature out-of-the-box. However we can write our own script or cron job which can automate creating tickets in JSD or Jira using Rest API. I am sure there are third party plugins which does this tasks smoothly, However my organisation doesn't want to invest further on such workflow. I am wondering if anybody gone through such task in your organisation to get some valuable feedback from your end.
Please do the needful,
It is quite common question. There are already lot of similar posts on the community on this topic.
If you are willing to do this outside Jira where you can control the frequency then it is quite simple task using REST API. You do that using a simple shell script (added to crontab) with a curl command or small python script.
You can start by looking here: https://docs.atlassian.com/software/jira/docs/api/REST/8.3.3/
This page will help you in understanding the api definitions. Look for Create issue.
If you want to do it within Jira there you will most likely need an app like Automation for Jira or ScriptRunner for Jira.
Ravi
